Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-02-2002, 01:26 PM
51dueller's Avatar
51dueller 51dueller is offline
2003 Ford Explorer Sport Trac
51dueller is gaining momentum as a positive member of FTE.51dueller is gaining momentum as a positive member of FTE.
How to identify a flathead?
I was wondering how to identify a flathead motor.
Thanks
Nathan
__________________
Nathan
You may have an Effie but I have a Emmie! TM
'51 Mercury M-3 Extra 5 Star Cab Dually "Faith"
5.4L, AOD, Dana 70 3.73:1, Twin-I-Beam
Built to play and work hard!
  #2 (permalink)
Old 10-02-2002, 04:30 PM
mtflat mtflat is offline
Garage is empty, add now
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Uh, could you be a little more specific Nathan?
4, 6, or one of the many variations of V8's 221/239/255/337 or Lincoln's V12? These were all produced during 1932-54. There were 3 main variations of the 221 alone.
There were earlier V8's by other mfgrs but not one-piece blocks and they were much heavier. That's what set Henry's apart from the rest.
Generally all have no valve covers - they are valve in block engines and the spark plugs stick out the top of the heads.
  #3 (permalink)
Old 10-03-2002, 01:06 PM
51dueller's Avatar
[updated:LAST EDITED ON 03-Oct-02 AT 02:07 PM (EST)]It's a flathead V-8. I was wondering if you could tell me where to look to get numbers and I'll post them.
Nathan
__________________
Nathan
  #4 (permalink)
Old 10-03-2002, 06:50 PM
Numbers on Ford flatheads is a very inexact science. Most numbers you'll find are only local foundry casting numbers, and so far no one has catalogged them.
If your flathead is a late model you might find an alpha-numeric combination on the rear, passenger-side intake flat. See the accompanying link.
[http://flatheaddrag.com/birthday.html]
Otherwise, you'll only be able to pin it down to a specific range of years. Collect numbers off the heads, watching for things such as a string that contains the numbers 6049/50 (Ford's right/left head pn) with a prefix like 18, 48, 99T 59, 8BA, EAB, etc.
Also, general things: How many fasteners (studs/bolts) on each head? 17, 21 or 24?
Where are the waterpumps? On the front of the block or on the heads?
When you get this info gathered, let me know and I'll go into more specific details.
  #5 (permalink)
Old 10-04-2002, 01:24 PM
51dueller's Avatar
It has EAB heads, distributor in the front. Is this a car engine? because it is in my parts truck.
Thanks
Nathan
__________________
Nathan
  #6 (permalink)
Old 10-04-2002, 05:53 PM
You narrowed it down a bit - EAB heads were used on '52, '53 truck engines. Trouble is, all 24 stud/bolt heads interchange from 1939 - 53 (54 Canada) with a few mods.
Is your distributor mounted on the end of the cam shaft at the front of the block ('32 until '47 trucks) or on a post angled toward the passenger side like modern engines?
Any luck with the assembly date as per the website? They are often stamped faintly, but if an engine was rebuilt and the block was shaved the numbers will be missing.
  #7 (permalink)
Old 10-04-2002, 07:39 PM
51dueller's Avatar
The distibiter it angled toward the passenger side. I didn't check the numbers because I haven't gotten around to it yet.
Nathan
__________________
Nathan
  #8 (permalink)
Old 10-05-2002, 12:06 PM
gary534 gary534 is offline
gary534 is starting off with a positive reputation.
Tags
casting, codes, eab, engine, flat, flathead, ford, head, identify, identifying, mercury, numbers, numbet, v12, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
