Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-05-2002, 05:21 PM
Bigran Bigran is offline
Garage is empty, add now
Bigran is starting off with a positive reputation.
Post Carter carb
I have a tractor with a conversion to a 6 cylinder flathead. It has a Carter carb on it. It says Carter YF also these numbers, 4494S and also -2282, and on one side of the carb 1947. Are there rebuild kits for these carbs and a manual for this engine so I can keep it maintained? Thank you.
  #2 (permalink)
Old 10-06-2002, 10:38 AM
54_5star 54_5star is offline
54_5star is starting off with a positive reputation.
Carter carb
Carter YF's were around for many years ( 50's and on ), so you should be able to find a rebuild kit for one. I think it was used on 300 Fords.
  #3 (permalink)
Old 10-15-2002, 08:54 PM
41Clay's Avatar
41Clay 41Clay is offline
41Clay is starting off with a positive reputation.
Carter carb
__________________
forum guidelines
Tags
carb, carbs, carter, ford, numbers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
