Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-15-2002, 09:12 PM
41Clay's Avatar
41Clay 41Clay is offline
Garage is empty, add now
41Clay is starting off with a positive reputation.
light rust on cylinder wall
I bought an engine that was subposivly running in the late eighties. Pulled the heads and found some recent but not bad rust, I'm guessing "flash rust." I was wondering if there was a solution that could take this out or if I could just use something like rubbing compound to remove it. I think it's in to good of shape to rebuild and want to start it up and check how it runs without scratching the cylinder walls up too much.
__________________
forum guidelines
  #2 (permalink)
Old 10-16-2002, 07:55 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Mine was in the same condition from the sounds of it. I used steel wool and penetrating oil (PBlaster, WD40, diesel, etc)and scrubbed. You might want to lay a rag on top the piston just to keep wool shards out of the rings. I got the worst of it that way and let the rings finish up.
  #3 (permalink)
Old 10-16-2002, 08:22 AM
Tags
cyclinders, cylinder, cylinders, egine, engine, ford, inside, light, lights, logo, rebuild, remove, rust, wall, walls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
