Trannys?
Old 11-27-2005, 09:30 AM
DANDEE1996's Avatar
DANDEE1996
DANDEE1996 is offline
Trannys?
WHAT TRANNYS WILL FIT ON A '48 FLATHEAD V8 59AB ENGINE?
Old 11-30-2005, 09:04 AM
51ford fan's Avatar
51ford fan
51ford fan is offline
You can use a C4, or a T5 5-Speed trans from an 83 to 88 S-10 truck or Blazer.
Old 12-01-2005, 09:16 AM
46fordtruck's Avatar
46fordtruck
46fordtruck is online now
The above will fit, but you need adaptors, they are not just bolt ons without the adaptors. You looking for stock trans or a later more modern trans? For the adaptors, check out www.flat-o.com
Old 01-11-2006, 09:54 AM
51ford fan's Avatar
51ford fan
I just finushed installing a 89 S10 5-speed in my 51 F1. If you go that route I'm sure you will be happy and quite as impressed with the difference as I'am.
Rod 51 F1
Old 01-16-2006, 09:49 PM
ron_29_1973's Avatar
ron_29_1973
ron_29_1973 is offline
48 ford f1 tran's
will a 5speed from a 84 thunderbird turbo coupe work on the flathead anyone tryed this???
Old 01-17-2006, 04:18 PM
51ford fan's Avatar
51ford fan
Don't quote me on this, but from what I understand you can mix-match t5 innards to achive what you want providing you have the resources to do so. I believe the input shaft might be different on the T-bird unit. If so, you might be able to swap it for an S10 input shaft. All else, the trans case demisions and mounting are all the same. Except the T-bird has the shifter location further back that the S10's do.
awq134
2009 - 2014 F150
12-25-2014 01:50 PM
f150crewcab
04-20-2012 12:13 PM
Smoove
2004 - 2008 F150
24
03-28-2011 10:10 PM
SteveBricks
Nova Scotia
17
12-23-2010 06:04 PM
DUALLYNOTED
09-01-2006 01:03 PM
Quick Reply: Trannys?
