Doors rattling
Doors rattling
We have an 07 F150 XL reg cab. I was wondering has anyone had a problem with the doors rattling going down a dirt or bumpy road. They sound almost as if door werent shut rite eventhough they are slammed shut. We took it in to the dealer and they said they adjusted and replaced door stops but we still have the same problem. plus they said they coud not duplicate.
My doors did this rattle as well (2008) crew cab), turns out there are these plasctic tabs (2 each door) that were not all the up, so I just had to slide them up till they were firmly in the slot. They are towards the very bottom of door, gotta kinda squat down to see'em, hope this helps ya, as it did in fact work for me as I thought doors weren't shut either.
Do you have a rattle or a thud?
I have a thud in my door also (crewcab) sounds like its coming from the drivers door, or pillar between the doors. I took it to the shop and they couldnt duplicate. It sounds just like you say,like the door isnt shut all the way but it is and I told him that.
So the SM and I went for a ride. The problem is that the passenger cant hear it you have to be in the drivers seat and then of course watch where your going, anyway we picked a road with hardly and traffic and I drove the truck until i found a spot that made it duplicate the sound, and told him to get in the drivers seat and do the same thing. He didnt hear it at first but after about 20 minutes he finally heard it. The thing is you dont have to be going that fast to hear it I think we were around 10 MPH.
Anyway by the time we got back to the shop the mechanic was on a different job. So I didnt get it fixed. But he looked at the alignment of the door from the outside and said it looked to him like everything was lined up correctly.
I still say its the darn latch and I told him that but like I said nobody had the time to look at it.
So basically I got feed up with it, it drives me nuts, thud, thud, thud.
My girlfriend told me to tune it out like I do with her
So I decided to take a towel not very thick, and kind of wrapped it around that loop latch on the truck, Not sure if it was the first or second part of the loop, then shut the door. You got to make sure that the towel isnt to thick otherwise the door wont shut all the way.
Anyway after I did that, guess what...No thud. I dont have the towel there now cause it always gets comes back out when you open the door.
Try it and see what happens with yours. If it takes the thud out then you know what it is and can tell the dealership.
Let us know......now i have to go diagnose the stupid noise coming from the rear of the truck, which happens when the rear flexes.
Thanks SD i will try that and see if it helps. I now have the Mr Clicks(owner) office wanting this taken care of. I got the call from my advisore today cause his boss came down on him. I gess after you have bought 4 cars from them they care about your buisness. I cant drive the truck. I just had surgery on my right hand.
I've got the 2007 XL Reg Cab too, and I took my truck in for the noise too. At first the techs couldn't reproduce the noise, so I went back out with them, and drove half on, and half off the road on the grass. Then, the tech could hear it. They fixed the passenger side, but the driver's side still has to be shut pretty firmly. I have found, that if you shut the door, and then grasp the front edge of the little door and pull out on it, if it moves, then either the top latch or bottom latch isn't latched. It will be a very noticeable movement. If it does move, it will rattle, at least mine will. Try it, and see if it works for you. My 2 cents worth, hope it helps. *****If somebody figures out how to adjust these door latches, please pass it on. It is a pain in the butt..........******
I have an '07 F150 super cab that does the same thing, but only when you don't slam the smaller rear doors. It's a little annoying to always slam them but that's the only thing that I found makes it stop. Maybe it has something to do with there being no b-pillar and the cab flexes a little. But like an earlier post stated, I only hear something if it is over a large bump or pothole.
It's hard to believe that a door rattle is normal. I know that Ford test extensively for water leaks, I wonder if it was rattling and leaking would they pay more attention to the problem?
