Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-02-2002, 05:29 PM
41Clay's Avatar
41Clay 41Clay is offline
Garage is empty, add now
41Clay is starting off with a positive reputation.
rpm
Isn't the normal max rpm of the flathead around 3600? Is there a way I can increase that to around 6000? What is holding the flathead back, is it just the breathing? It may sound crazy but I will appreciate any opinions/facts on this.
__________________
forum guidelines
  #2 (permalink)
Old 11-04-2002, 07:37 AM
chukm chukm is offline
chukm is starting off with a positive reputation.
rpm
That is most likely the rpm @ peak HP not redline.
  #3 (permalink)
Old 11-04-2002, 04:42 PM
41Clay's Avatar
rpm
[updated:LAST EDITED ON 04-Nov-02 AT 05:51 PM (EST)]Ok, so is it around 4200rpm? I'm thinking about replacing an engine that sees 4000rpm regularly and maxes at 70000rpm.
I'm looking at an 8BA 239 block. I would put on a girdle for the main caps, of course the full flow oiling, keep the compression about the same for the higher spinning, and an electronic ignition. Probribly go with a 390cmf quad, or adapt a holley 2300.
__________________
forum guidelines
  #4 (permalink)
Old 11-04-2002, 07:22 PM
tcw tcw is offline
tcw is starting off with a positive reputation.
rpm
Tags
flathead, ford, redline, rpm, safe, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
