Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Oklahoma Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
  #1 (permalink)
Old 05-21-2008, 01:03 PM
1973FordRanger4X4 1973FordRanger4X4 is offline
Garage is empty, add now
1973FordRanger4X4 is starting off with a positive reputation.
Unhappy electrical issues
I'm having an issue with the altinator not charging the battery. The battery and altinator and regulator are new so i dont understand why the powers not getting to the battery to charge it. The battery and altinator have been tested and work. Any help would be appreciated, im in the Enid Ok area so if ur a local maybe u could look at it and help me out?
  #2 (permalink)
Old 05-21-2008, 06:57 PM
jwtimme jwtimme is offline
jwtimme is starting off with a positive reputation.
I have had bad alternators test good because the kids working the counters don't know what they are doing. Make sure they put the alternator under a load when they test it.
Also make sure that you have good connections at the solenoid and positive battery post.
  #3 (permalink)
Old 05-21-2008, 07:08 PM
Unhappy
yeah i have done all the above and still no good charging. I think it might be a fuseable link but i dont know where the one is that runs between the battery and altinator.
  #4 (permalink)
Old 05-21-2008, 08:11 PM
How are you checking the charging of the alternator? And if you think there is a problem with the wiring then run a wire from the alternator to the battery.
  #5 (permalink)
Old 05-29-2008, 05:31 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader SwOkcOffRoader is offline
1952 Ford F-1
My Garage
SwOkcOffRoader has a good reputation on FTE.SwOkcOffRoader has a good reputation on FTE.
once i had that problem, after i changed the alt and reg, it stopped charging...i had to put a capasiter (sp?) on the regulator....i noticed my 78 had this thing on it but my 76 didnt....i just swapped it over and it has worked fine since...if your regulator dont already have one, there will be a yellow wire that isnt hooked up on the regulator, thats what it hooks to....i hope this helps....
Click the image to open in full size.
__________________
Why is there never enough time to do it right the first time, but always enough time to do it again??
....Will work for Rep points....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
