Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-11-2002, 08:39 AM
2speed 2speed is offline
Garage is empty, add now
2speed is starting off with a positive reputation.
Autolite 2100
Anyone ever put an Autolite 2100 on a Flathead? Has the higher CFM, supposedly the best carburator ever built and a WHOLE lot cheaper than a Holley 390. I was thinking of making an adapter plate to fit on the stock manifold. Anyone try this? Does the stock manifold have a CFM limit?
  #2 (permalink)
Old 12-11-2002, 04:56 PM
51dueller's Avatar
51dueller 51dueller is offline
2003 Ford Explorer Sport Trac
51dueller is gaining momentum as a positive member of FTE.51dueller is gaining momentum as a positive member of FTE.
Autolite 2100
Susposivly the most cfm the flathead can handle is 390.
Nathan
__________________
Nathan
You may have an Effie but I have a Emmie! TM
'51 Mercury M-3 Extra 5 Star Cab Dually "Faith"
5.4L, AOD, Dana 70 3.73:1, Twin-I-Beam
Built to play and work hard!
  #3 (permalink)
Old 12-12-2002, 04:21 PM
fordguy76's Avatar
fordguy76 fordguy76 is offline
1978 Ford F-150
fordguy76 is starting off with a positive reputation.
Autolite 2100
__________________
seth cooper
78 F-150 4x4
Ranger XLT
4 inch Skyjacker lift
71 429 4bbl
Tags
2100, aod, autolite, carb, flathead, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
