97 PSD dash shift indicator problem
Welcome to the site.
Unfasten the lower portion of the steering column cover. You don't need to completely remove it, just loosen it enough to pull the right side down to expose a thumb-wheel screw. Mine is black.
Place the gear selector lever in the gear you want. Turn the thumb-wheel clockwise or counter-clockwise to adjust the needle indicator. Move the gear selector lever through all gear positions to ensure you have the correct adjustment.
When you have the needle adjustment where you want it, tighten the steering column cover screws and you're done.
1Badgunny
02-21-2011 11:33 PM
