Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-20-2008, 10:59 PM
Hillcapper is starting off with a positive reputation.
Intake porting question
Yes, I'm still porting on my E7's. Got the exhaust side done on the first head. Turned out pretty good. Now for the dumb question. There doesnt seem to be a lot of opportunity for gasket matching on the intake side. Gasket seems to line up pretty close. Problem is with the angled mounting holes its hard to know if gasket is actually lined up correctly. Gasket also looks to fit either way I put it on (with head side toward head). Any pointers? Hemieater I've used your pictures (along with some advice from others) as a guide for porting. Will do the same on the intake side porting and I realize there looks to be less material to be removed other than some valve shrouding. Hemieater, Conanski, anyone.....anyone.....
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-20-2008, 11:23 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Yo have seen this website haven't you... diyPorting.com
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's, FRPP Mass Air, TweecerRT 282HP
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
