12 volt conversion - Ford Truck Enthusiasts Forums
12 volt conversion
Old 09-01-2002, 12:19 PM
51dueller's Avatar
51dueller 51dueller is offline
51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.
12 volt conversion
What is needed to be changed for a flathead to run on 12 volts?
Thanks
Nathan
Old 10-11-2002, 07:42 PM
leverettq5l4 leverettq5l4 is offline
leverettq5l4 is starting off with a positive reputation.
Post 12 volt conversion
Hi Nathan,
You will need a generator from a '56 to '64 Ford car or F-100. Then you'll need to drill a hole in the side on the new generator to match the dowel pin in the bracket where the 6 volt generator was.The voltage regulator from the same family of Fords the 12 volt generator fits will bolt directly to your firewall.Be sure to get a 30 amp generator/voltage regulator as they are more readily availible. I know some people have used GM style one wire alternators when converting, but this setup will look more like it belongs there in My opinion.Next,you will need a 12 volt solinoid with an insulated base.This should connect with your starter button the same as the 6 volt one did. You'll need to change your coil to a 12 volt coil with a built in ballast resistor.This will keep your points from burning.The other thing you'll need to do is put a resistor in the common wire feeding your gauges.This way you can still use all the 6 volt sending units.The ammeter is an induction type with a wire that runs through a loop. You will need to run that wire back through in the opposite direction so the polarity will be correct for 12 volt negitive ground.You can leave the 6 volt starter in place because for no longer than it takes to start your truck it will last a long time.Mine has lasted 20 years.Also, when your engine is tuned up properly, just a quick bump or the starter and it will be running!The last things you'll need to do is to change all your bulbs and turn signal flasher to 12 volt and get a 12 volt heater motor. Leverett Fernald
Old 11-12-2002, 10:55 AM
saxtonj's Avatar
saxtonj saxtonj is offline
saxtonj is starting off with a positive reputation.
12 volt conversion
leverettq5l4,
I have a question as I was considering changing my '49 to 12V Neg ground...
Wouldn't you have to re-connect each gauge wire on the opposite terminal to reverse the polarity of each gauge as you mentioned with the amp gauge?
Thanks,
James
Old 11-12-2002, 08:39 PM
Hi saxtonj,
With the exception of the voltage reducer, I left the way the oil, fuel and temp gauges were wired and they work fine.That was a good point to bring up,though.
Leverett Fernald
Old 12-24-2002, 12:49 AM
b1ken b1ken is offline
b1ken is starting off with a positive reputation.
12 volt conversion
What value resistor did you use for the gauges (ohms & watts).
Old 01-05-2003, 01:07 PM
I used a 12-6 volt ignition resistor for the gage cluster on my trucks. I do not know the value. Sorry it has taken so long to respond, but I had a setting problem with my computer and just got it repaired today. Leverett Fernald
Old 01-05-2003, 02:16 PM
84MustangGT 84MustangGT is offline
84MustangGT is starting off with a positive reputation.
12 volt conversion
tps signal out to pcm Uncle JimBod 1987 - 1996 F150 & Larger F-Series Trucks 10 07-04-2014 03:34 PM
converting a 6 volt to 12 volt...how difficult is this? jhaas63 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 09-30-2012 11:33 PM
223 inline six 6 volt to 12 volt conversion HkyswiM 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 11-16-2011 05:24 PM
6 volt coil scott0531 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 08-06-2008 02:17 AM
Diehard battery charger, need some instructions please 78bigunns Garage & Workshop 5 11-18-2002 03:32 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
12, 12v, 1948, conversion, convert, converting, f1, flathead, ford, generator, generators, moreinformation, vold, volt, volts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
