adjustable lifters?
adjustable lifters?
I saw an ad in which a guy is selling a 49ish ford with a flatty. It said that is has adjustable lifters from a company called Johnson which has a screw type adjuster on it to set the valve clearences.
Has anyone ever heard of this?
I am confused because I thought the flattys don't have lifters, the valve stems rest right along the cam.
Now I could understand if the valves had a screw to adjust the overall length.
Chris
Chris
adjustable lifters?
Hi Chenders,
Flat motors have lifters - what they don't have is pushrods because the valves aren't upside down over the pistons.
There have been adjustable lifters around for decades. If you are working on a high-performance flatty make sure you get a set of old adjustables. The new ones are heavier and thus slow things down.
Funny, that under stock spec conditions Henry's stock lifters are the lightest and best. Only in race engines where the cam is ground drastically or other 'improvements' are made do you even need adjustable lifters. Unless, of course, you just want to be able to say you got 'em.
Tim
Tim
scottiethebarber
10-06-2015 02:36 PM
55 f350
08-29-2012 06:30 PM
herbie
11-27-2005 03:03 PM
Randyb12
04-01-2004 10:23 AM
