Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-20-2008, 05:15 PM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Follow up on headers
So the question was asked if headers for a 4.0L Ranger or Explorer would work on an Aerostar. I now have all the dirty details on the answer.
To simply get to the point, the answer is no.
The Aerostar has suspension components and frame members right in the way of where the oil filter would be located on the passenger side. As a result, the oil filter is mounted on an adapter that is different from the one found on the Ranger and Explorer. As a result, the exhaust, which passes through the same region, is also different. The headers will hit against the oil filter bracket, and would require serious modifications to make them fit. The drivers side fits just fine, no issues. The y-pipe would also need to be modified, most the headers come with a new y-pipe for the Ranger/Explorer, because the headers are longer than the factory manifolds.
So sorry for the bad news. Best I could tell, all the headers I looked at were basically the same.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-20-2008, 08:50 PM
93nighthawk's Avatar
93nighthawk is starting off with a positive reputation.
bummer......
__________________
'96 Ford Contour 2.0 I4 MTX 77k mi- Rear Ended 12/22/07
'97 Ford Aerostar AWD 4.0L v6 AT 81kmi
'97 Chevy Lumina 3.1 v6 ATX 135k mi Parents old beater, temp vehicle
Future: 2009/10 Taurus SHO, Loaded
My Car Domain
The Possum Aero-Van!
  #3 (permalink)
Old 05-20-2008, 08:59 PM
96_4wdr's Avatar
96_4wdr is gaining momentum as a positive member of FTE.
put on a remote filter sandwich adapter plate and remote mount an oil filter
done all the time on Rangers to protect the filter from rock and limb damage.
leaves lots of room
also makies adding an oil cooler easy
  #4 (permalink)
Old 05-20-2008, 11:47 PM
Sponsor
I tried that, my oil pressure dropped dramatically, to the point where I had lifter noise. I switched back to stock promptly, and the problem went away. Maybe the adapter I got is not free flowing enough, or the oil lines are too small. If you go with an adapter, the headers will fit. I will reinvestigate the relocation. Any advise on where to move the filter to would be welcome. The Ranger has more options, but the Aerostar is too crowded in all the desirable areas.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
  #5 (permalink)
Old 05-21-2008, 03:49 AM
96_4wdr's Avatar
Universal & Light Truck Oil Filter Relocation Kits
use rt. angle fittings out of block plate and oil pressure rated neoprene hose.
no sharp bends in hoses.
mounted mine on frame rail. keep the filter low, helps keep oil pressure up, reduces oil pump work load and engine off drain back
use only a fin and plate cooler if you add one, too much pressure drop with the coil tube type.
Engine cooler 1/2 NPT fittings: Bulkpart transmission parts
  #6 (permalink)
Old 05-21-2008, 05:35 AM
DCRB is starting off with a positive reputation.
any info on 3l headers yet? j/w
__________________
93 3.0l xlt extended aerostar
mods:
800 watt sound system.
200+ farad kenetic battery + 875 cca reg. battery
2" catback exhaust w new flexpipe and cherry bomb muffler.
4g alt. wiring
Gutted stock airbox
2nd row bucket seats
'89 civic shell "PROJECT EF"
'89 civic donor car
  #7 (permalink)
Old 05-21-2008, 10:53 AM
96_4wdr's Avatar
pre mid 90s 3L Ranger headers should fit with some work. oil filter, exhaust pipes, etc.
  #8 (permalink)
Old 05-21-2008, 12:22 PM
Sponsor
Where on the frame rail did you put it? Do you have any pics. I would be interested in pursuing this further.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
  #9 (permalink)
Old 05-22-2008, 01:43 AM
96_4wdr's Avatar
horizontal on outside of frame rail. 2 1" holes thru frame for hoses
put a 6" sheet metal plate in front of it to block front tire spray
good place for cooler is just behind filter at an angle
just have to remember to take all the brush and high center rocks on the driver side.
  #10 (permalink)
Old 05-22-2008, 10:51 AM
Sponsor
What dd you use to cut the holes through the frame?
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
  #11 (permalink)
Old 05-24-2008, 11:24 AM
marty600 is starting off with a positive reputation.
Bear River: what brand did you use? (oil relocation device)
I wanted to do the following, but i dunno, too expensive...
AMSOIL By-Pass Filter Installation - 1992 Ford Aerostar XLT 4.0 Liter
__________________
'01 Escape 2.0 5 speed- 88k
'96 Cherokee 5 speed- 115k
'92 Mercedes 2.5l turbo diesel- 209k
'90 Aerostar ext Cargo 4.0- 29k
'02 ZX2- 69k
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
