Quote:
Originally Posted by JCastellaw
Where can you get a vented cap??
Is it hard to get fuel on your tank????
This is the pre emission one:
Gas Cap, Chrome 66-70
This is non-vented one:
Gas Cap, Chrome 71-76
I have that same poly ethylene tank. What a piece of junk. When I fill it up the weight of the fuel makes the tank sag around the strap.
Maybe I'm not suppose to use the factory mounting strap with it
I think I'm going to get the 23 gallon steel tank.
If I remember correctly (I'm not in garage at moment) my fuel filler neck (that came out of a 73) had a small hose that connected the tank with the upper end of the filler neck which would prevent the fuel from backing up while filling. See here:
Vent Hose, Rear Tank, 66-77
The other port got plugged.
Regards
Ken
