Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 05-19-2008, 11:34 PM
camodown's Avatar
camodown camodown is offline
Garage is empty, add now
camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.
How to rear hub seals and parking brake shoes
Well, it was time to do rear hub seals on my truck so I took some pictures and am doing another how to. Hope this helps people! This is for a 2002 F-350 10.5" rear. Please consult appropriate shop manuals to get exact torque specs for fasteners...
Follow for links to shop manuals: http://www.ford-trucks.com/forums/74...nual-link.html
Disclaimer: Ford-trucks and I are not responsible for anything which can result from mis installation or other issues that may arise from following this tutorial.
You will need:
-A 150 ft lb torque wrench
-gear lube
-2 jaw puller and step plate
-Ford Rear hub socket (available at parts houses. Autozone didn't have one)
-Rear hub seals (I'd do both. My drivers failed and passengers was starting to weep)
-O-rings for axle shaft
-Ford spec thread locker (i.e. Loc-tite)
-Bearing repack (grease)
-Jack and stands
-Rear park brake shoes (Kit ran me $97 from dealer)
-brake cleaner
Note: Although the park brake shoes aren't cheap, buy them as usually your hub seals will leak gear lube all over them rendering them useless.
First, buy all your parts. The hub seals are PN: 2C3Z-1177-AB while the o-rings are PN ESTZ-4A331-A. Hub seals run about $16 while the o rings are about $1.50.
Here are PN's and pictures showing fastener sizes:
Don't mind the brake fluid. I was flushing my system.
Start by SAFELY jacking the truck up and using jack stands. Note: Yes, I am using a jack. My jack stands couldn't be found. DO NOT DO THIS. NEVER WORK ON A VEHICLE SUPPORTED BY A JACK. I had to get the job done.
Remove the fancy lug nut covers using a large screw driver/ end of lug wrench. place upside down to place fasteners in.
Loosen the lugs and remove wheel assembly.
Place drain pan below axle shaft.
Loosen and remove axle shaft retaining bolts and pull out axle shaft. It is in there tight but will come out. It will leak a little gear lube so be watchful.
Remove rear brake caliper and bracket. Careful, its kind of heavy. Set aside but do NOT hang by brake hose
Remove brake disc rotor
Using special socket, loosen the hub nut and remove. If it falls apart replace the nut. Also watch that the inner bearing doesn't fall onto the ground. Sorry I don't have a better picture of the socket. Socket is circled in red, spindle nut is in blue
Remove hub using puller and step plate. I didn't need either. My hub came off with a little prying from behind.
Remove retainers for brake shoes as well as springs. Using brake cleaner, clean really well where any lube is. Don't want to ruin new brake shoes. Take note that the long spring goes in top of the fat one so as to not rub the hub. When going to replace the rear shoes, I covered the spindle so as to not scratch it. The springs tend to cause the shoe brackets to make contact with the spindle.
Repack bearings with appropriate grease and remove old hub seal.
Drive in new hub seal. Make sure it bottoms out properly. NOTE: Make sure you replace the inner bearing before you drive the seal in. I almost didn't. These seals are NOT removable once driven into place.
Coat spindle with a bit of axle lube and fill cavity with a little lubricant. Place hub onto spindle taking care not to nick the new seal on the threads of the spindle. Place the outer bearing back in place making sure it is seated fully, then put on the spindle nut and tighten down to 60 ft-lbs, then back off nut 7 clicks for used bearings. (CHECK YOU TORQUE SPECS. These are for an 02 and 10.5" rear end...Yours MAY be different!)
Replace axle shaft and fasteners using Ford spec thread locker, as well as replace o ring on axle shaft end
Replace rotor and caliper bracket using proper torque specs
Clean and grease slide pins with slide pin lubricant, replace caliper using proper torque specs, replace wheel assembly, tighten lugs to torque, THEN tighten axle shaft retaining bolts.
Congratulations. You have replaced you rear hub seal(s). Other side is the same, but with opposite threads.
  #2 (permalink)
Old 05-20-2008, 07:05 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Hey, another write up with pics. That's the best kind. Good job. Reps sent.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 400,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #3 (permalink)
Old 05-20-2008, 07:47 AM
WILDMAN_Stroker*7.3's Avatar
WILDMAN_Stroker*7.3 WILDMAN_Stroker*7.3 is offline
WILDMAN_Stroker*7.3 is gaining momentum as a positive member of FTE.
Thumbs up
That is a great write up, Because I'm getting ready o do the parking brake thing as well. Thanks alot. REP POINTS SENT
  #4 (permalink)
Old 05-20-2008, 07:52 AM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant future
Roland Mueck
Good job. Thanks for sharing. Reps sent also.
__________________
Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner F6 (live tuned), AFE II w/ Pete's Cover, GTP38R w/ 1.15, 6.0 Techni-cooler IC, Full Force SS Injectors, Stealth HPOP, Fluidampr, Melling M-208, Walbro FP, mueckster Reg Return & Fuel Bowl delete, 910 Springs, mueckster built 4R100, 4" SS MBRP, TruCool, billet 710 cap, Truetrac rear
PAA Member #62
... From Rock to Rocket-- Thanks to the Brotherhood.
  #5 (permalink)
Old 05-20-2008, 06:04 PM
camodown's Avatar
Thanks everyone. I just like playing around with the new digi cam and hoped someone could get some use out of my pictures haha. Oh, one note I forgot. The hub nut has a tang on it almost like a key way. Make sure you line that back up with the notch on spindle or the nut wont' go on... Thanks again to everyone!!
  #6 (permalink)
Old 05-20-2008, 06:23 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
1999 Ford F-250
PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.
Great write-up and pics Camodown. Thanks. Rep Sent.
  #7 (permalink)
Old 05-21-2008, 02:49 PM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
2002 Ford Excursion
My Garage
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
Maybe Guzzle will add this to his site...
__________________
Nyx - 1999.5 F250 CCSB 7.3PSD Lariat, 38R, DP F5, BTS VB, 6.0 IC & tranny cooler, Kenwood DDX516 & XM radio
  #8 (permalink)
Old 05-21-2008, 03:05 PM
PaysonPSD's Avatar
Support FTE
1999 Ford F-250
Quote:
Good point, and good Idea.
  #9 (permalink)
Old 06-09-2008, 10:10 PM
fish_hunter2 fish_hunter2 is offline
fish_hunter2 is starting off with a positive reputation.
I am in the midst of doing my 99 F350 Superduty right now. Looked on the web site to see if there was some info on changing the rear seals and wow, your photos look just like my truck, oily brake pads and all. Thanks for taking the time to post this. I should have done the same when I rebuilt my front end. Didn't know about this site then. Thanks again.
  #10 (permalink)
Old 06-10-2008, 01:14 AM
big poppa's Avatar
big poppa big poppa is offline
Country Cadillac
big poppa has a brilliant futurebig poppa has a brilliant futurebig poppa has a brilliant futurebig poppa has a brilliant futurebig poppa has a brilliant futurebig poppa has a brilliant futurebig poppa has a brilliant futurebig poppa has a brilliant futurebig poppa has a brilliant futurebig poppa has a brilliant futurebig poppa has a brilliant future
The pics really make it alot easier, nice job, reps sent.
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto w/182,000 and counting. To much to list.... PAA#26 Wife's: 97 Expy XLT 4.6 4x4 comp. stock 137,000
  #11 (permalink)
Old 06-23-2008, 06:34 AM
weldude weldude is offline
weldude is starting off with a positive reputation.
Great info guys.
This is great info. Only my truck is a dually and 2005 model. I am guessing it will be about the same just bigger and longer parts to work with. My big question is about pulling the axle out. I was told by one guy I woud have to remove the diff cover and un bolt the axle someway from the rear end gears ? Then slide it out. Any ideas on this ? Plus mine has disc rear brakes. THANKS
  #12 (permalink)
Old 09-24-2008, 08:48 AM
eckart's Avatar
eckart eckart is offline
eckart is starting off with a positive reputation.
Great info as always guys. Thanks. Thought I would look and see what I did wrong cause both new rear seals are leaking.There was no leak before I did them. $72.- for 2 seals from Lordco. Still don't know what I did wrong other than doing it on a Sunday and having to buy them from Lordco. Guess I"ll go to Ford and get 2 more seals and try it again.
__________________
1999 F350 sd sb/sc 4X4 6spd PSD
  #13 (permalink)
Old 09-24-2008, 08:59 AM
zack7.3's Avatar
zack7.3 zack7.3 is offline
zack7.3 is gaining momentum as a positive member of FTE.zack7.3 is gaining momentum as a positive member of FTE.
Great write up. I am saving this one because my drivers side just started leaking. Reps sent.
__________________
ZACK
99 1/4 F250 7.3 PSD 4x4
A few mods
PAA Member # 36
  #14 (permalink)
Old 09-24-2008, 09:33 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
That is one greasy looking parking brake!!! Nice writeup and reps to you.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #15 (permalink)
Old 09-24-2008, 09:51 AM
03_PSD's Avatar
03_PSD 03_PSD is offline
2003 Ford F-250
03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.
saving for future use, thanks and great writeup!!
__________________
Glenn
03 F250 Lariat 4x4~6 Gears~ProComp Lift~PHP Phoenix~4 Gauges~Van Turbo~5" Exh~AFE BHAF~ITP OBA~RDP AIH Delete~SS HPX~CCV~CCK RR~DS Coolant Filter~Alum. Rear Diff~Smoke Cab Lights~IH Emblems~Fumoto Plug~UP-PIPES~08 Console~Harley Rims~Harley Eyes w/RS HID kit~05 Facelift
Tags
2005, brake, f550, ford, hub, nut, powerstroke, rear, replacement, seal, shoe, socket, spindle, tight, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
