Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- How To Change Disc Brake Pads
Step by step instructions for do-it-yourself repairs
- How To Replace Emergency Brake
How to rear hub seals and parking brake shoes
#121
From this article:
93 f250: steps to replace a right rear axle seal..cab..4wd
Hub Nut Installation
- Install Hub Wrench Tool T85T-4252-AH on spindle.
- Tighten hub nut to 75-88 Nm (55-65 ft-lb). Rotate hub occasionally while tightening. NOTE: The hub nut will ratchet as torque is applied.
- Hub nut adjustment:
- For new bearings, after tightening to specification 75-88 Nm (55-65 ft-lb), ratchet back five teeth or notches on the hub nut. Five clicks must be heard during this operation in order to have performed it correctly.
- For used bearings, after tightening to specification 75-88 Nm (55-65 ft-lb), ratchet back eight teeth or notches on the hub nut. Eight clicks must be heard during this operation in order to have performed it correctly.
#123
excellent article from 2008.
One question i had was do the wheel bearing come out with everything and should they be replaced along with the new park brake shoes, seals etc.
is there a way to check bearing to see if they are bad. looking at close to 172K miles on truck and believe are original stuff.
have no leaks on rears thus far so should i worry or just wait till it leaks. ?? trying to get truck ready for life on the road in 4 yrs. would rather do this in a couple of years from now, that do it in the middle of B F E
#124
You can jack the truck up and wiggle the wheel to see if there is any play up and down and side to side. if there is, you may just need to tighten the nut some. the only way to check the bearings is to look at them. if you have to take them out you will need new seals. clean the bearings up very good. if there is no pitting or scoring on the bearings or race's they are still good.
#126
#128
ok thanks. Much appreciated.
I bought this remaned axle maybe 3-4 years ago (POS is already leaking) so Im changing seals, bearings (cheap as hell) and shoes because they are contaminated with oil. I digress...I don't know what type of gear oil was used by the manufacturer or if any friction modifier was used. Will adding some additional modifier cause the limited slip to act more quickly? Its very slow to react. Or is the modifier just for noise reduction?
#129
#130
The modifier actually allows the clutches to slip when going around turns. Adding more would make the clutches more slippery. If the limited slip is acting like it's not engaging, there may be too much in it already. The noise is caused by excessive binding in the gears by the clutches not wanting to slip. It also is trying to force both wheels to turn at the same speed which is hard on the components when turning. If you are in an empty parking lot and can do figure 8's and you don't hear or feel anything, you have plenty of modifier in the differential.
#131
#132
bnovak
1997-2006 Expedition & Navigator
22
09-25-2016 10:40 AM
davlun
25
08-17-2014 03:00 AM
Sawbones25
03-05-2008 10:36 PM
