Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- How To Change Disc Brake Pads
Step by step instructions for do-it-yourself repairs
- How To Replace Emergency Brake
How to rear hub seals and parking brake shoes
on
I just finished replacing the rotor/pads on my dually.. Had to remove the outer bearing and axle to remove the rotor.. But, i am wondering if I screwed up. You mention repacking the wheel bearings with grease... I thought the rear-end fluid lubed the bearings..Or is a single axle different from a dually when it comes to lubing the bearings?
In most cases you are right. However, there are some ford trucks that do have left hand threads on the drivers side (left side) rear spindle. Also, as noted, use some gear oil in the hub before putting the nut on. Grease alone may not be enough. In fact, I have replaced spindles that people packed with grease. Too much grease on the outer bearing prevents the oil from flowing through the bearing and getting to the inner bearing, causing it to burn up.
on
I agree ... I think i will keep using the gear oil to lubed the bearing on assembly.. Don't like mixing lubricants. I always think of the tragic accident involving the Alaska airlines MD80 off the coast of California a while back.. It turn out to be the mechanics were mixing lubricants that galled the jack screw .
#28
Great writeup!
I have added a couple of 2nd party writeups to the site because the only ones I can document myself are the maintenace items that I have performed on my truck and there is only so much that one truck needs. I basically only have one rule .... LOTS OF PICTURES!
I welcome other authors writeups on the site but they have to be submitted by the author. This way they can change the wording if they find that there is a "better way" to do something plus they need to send the original pics for re-sizing on the site. This also gives the author full control over the article if they want to make changes later as the author just simply e-mails the necessary changes. I know that I have found it necessary to change a number of things in my writeups.
All 2nd party writeups are approved by the original author before they are published on the site.
#29
I, too, don't like mixing different base lubricants. However,
From Wikipedia: http://en.wikipedia.org/wiki/Alaska_Airlines_Flight_261
"The NTSB considered a number of potential reasons for this excessive wear, including the substitution by Alaska Airlines (with the approval of the aircraft manufacturer Boeing) of Aeroshell 33 grease instead of the previously approved lubricant, Mobilgrease 28. The use of Aeroshell 33 was found not be a factor in this accident.[6] Insufficient lubrication of the components was also considered as a reason for the wear. Examination of the jackscrew and acme nut revealed that no effective lubrication was present on these components at the time of the accident. Ultimately the lack of lubrication, and resulting excessive wear of the threads, were determined to be the direct causes of the accident."
It's number 21 of the NTSB's "Conclusions" section of its Final Report.
http://www.ntsb.gov/publictn/2002/AAR0201.pdf
Though having different base stocks, and different thickeners, Aeroshell 33 and Mobilgrease 28 both meet MIL-G-81322, though they are each qualified to different suffixes.
As a side-note, one of the members of our Springer rescue organization was supposed to have been the PIC of that flight, and had swapped flights with another pilot. He knew both the cockpit crew. ESRA has three ATC left-seaters among its members.
Pop
Pop
