Pulleys? Need Help
Pulleys? Need Help
Ok I know someone knows the answer to this simple question. The dampner pulley on most Y-Blocks was a single sheave and if you added power steering to a car it would have a separate single sheave pulley which bolted to the dampner. I want/need to run a dual sheave dampner for a/c and Ford does in fact make one. I need to know will the p/s bolt on pulley still work with the dual sheave dampner?
Thanks Charles
Thanks Charles
