05-19-2008, 05:59 PM
EFI to carb..you have to scrap the efi stuff, ecu, tidy up the wireing. Anything run by or effected by the ecu has to be tended to, like the speedo. In your case, your speed is probably still cable driven. Instrument wiring will be interesting.
I doubt your 2wd C6 will work with your TC. Look under it if you don't know, but isn't your TC married to your trans?
You can get the same HP, but at higher RPM. YOu could go 393 and end up with decent low end torque, and keep your lighter engine and all systems going.
Does the wagon run? Drive it for a while till you get work. If it drives good enough, (like a hippo on wet clay is normal) you can prep your truck and decide if you want to fiddle with the 351 or 429'er.
