Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-19-2008, 04:22 PM
Eagle460's Avatar
Eagle460 is starting off with a positive reputation.
Smile 77 351M, Timing chain slack
Hey,
I pulled my water pump because it was leaking, I figured that since I was taking it apart, I would check the timing set for wear, everything looks to be in good condition (motor was rebuilt 50k ago.)
One side of the timing chain is always loose, and the other side is tight, and when I rotate the crank just a bit, it's the exact opposite. I don't see anything wrong, but I thought I'd ask if this was alright just in case.
Oh, and on my 2 piece fuel pump eccentric, the outer cup has some play, could this be a problem, or is that the way it should be?
Thanks a bunch!
PS+Here are a few pic's of the timing set
__________________
77' Ford F-150 4x4-351M
00' Ford F-150 4x4 5.4L
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-19-2008, 06:16 PM
80broncoman is starting off with a positive reputation.
I didn't think they still sold those nylon covered cam gears any more. I haven't seen one in years. Honsetly I'd replace the timing set with a good quality double roller chain set.
Since you down that far. I'd not worry about the fuel pump eccentric.that looks to be normal.
__________________
Real men don't wear Bowties
  #3 (permalink)
Old 05-19-2008, 08:54 PM
hollenjoe is starting off with a positive reputation.
If its new itas an oem replacement, cuz it loooks like the stock retarded crap, you should defenitivley change to a doble roller...
__________________
"All right baby, see what I´ve got right here in my hands, I´ve got it right in my hands to score you baby, I think im gonna yank on a one town! Look Out!" Uncle Ted
  #4 (permalink)
Old 05-20-2008, 08:51 PM
trinogt is starting off with a positive reputation.
Search the forums here, as the specific years Ford used a retarded timing set can be found somewhere... If it is indeed a retarded (valve timing) set, definitely get a new set with multi-index sprocket, and set it at zero, straight up.
The slack in the chain is normal. I believe a half inch is max, and the method to measure actually involves rotating the engine to tighten the chain on one side to measure slack on the other. No problem.
As for longevity, I have a stock timing set on my '78 351M, and it has not failed in over 500,000 miles. Might just be lucky? lol
__________________
Mark in FL
restoretherepublic.com
  #5 (permalink)
Old 05-20-2008, 08:57 PM
hmmm in the lowe part of the big gear you can see a D0xx casting number meaning it could be a 70s 351c timing chain? could it be?
__________________
  #6 (permalink)
Old 05-20-2008, 11:59 PM
Eagle460's Avatar
Hmm...I wonder if you could be right... The chain that is on the engine right now has a little more than 3/4 slack when we tested...time to get a new timing set?
I keep hearing about how the stock set on the 351M is retarded for emissions reasons. Will getting a timing set that is not retarded result in more power? I'm looking at a double roller set since their cheap. What would you suggest?
Thanks
__________________
  #7 (permalink)
Old 05-21-2008, 04:52 PM
I believe the straight up timing set will give you better midrange and top end power compared to the retarded timing.
3/4 inch slack seems excessive...
Double roller is the only way to go.
You will see the '0' keyway on the crank sprocket. Just line up the marks on the cam to the '0' keyway of the crank and away you go!
__________________
Mark in FL
  #8 (permalink)
Old 05-21-2008, 05:34 PM
JBradley500 is starting off with a positive reputation.
i think its only supposed to have 1/2" of slack.
__________________
New Plan...
410ci, 10:1, AFD 57cc 2v Heads, Edelbrock Intake and Phenolic Spacer, 725 cfm Road Demon, Roller 219/222 @.050 .535 lift 108 lsa, Bee-Hives, Dual Roller Chain, ARP's, MSD Pro Billet, Hedman Headers, Milodon Pan and HV Water Pump.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
