Archived PA Buy/Sell/Trade Ads
#61
I got some stuff to sell too if anyone is interested:
A SuperVisor sun visor for 73-79 F series, new, unpainted, still in the box,$50.
A good dash pad (top) for 80-86 F series, used, black, no cracks or damage $35
2 rear springs from a 91 F Superduty 4X2 complete with hangers all parts in good shape $75 each or $125 for the pair.
A rear axle assy. from an 89 F350 4X2 cab and chassis. 10.25 ring gear, 3.55 ratio, no posi.Complete bolt in unit with axles and drums.Will fit a truck with 34" wide frame rails.$400.
6 steel wheels from 89 F350. 16" , 8 bolt. $25 each
I'm willing to dicker a bit or trade for 67-72 body parts.Please p/m me if you are interested.Thanks.
#62
i've got a dana 50 ttb out of my '96 f-250. 4:10 gears. spindle to spindle. ball joints and pivot bushings with less than 10k on them, tie rods all tight but needs tie rod dust boots. have the calipers and rotors. rotors could use a turning to smooth them out. make offers. i'll be at the pa nj de meet and greet april 21st if interested to pick up then
i also have 2 steel dually wheels from a '94 f-350 dually. will need refinishing
#63
2nd bronco
hey guys since you guys are from pa i have another bronco full size i am traying to sell the truck she needs some work , i just can have two of them if anyone is interested i am selling her for $800 or best offer i got the truck for my mom but she left the state and i got stock with it so i can go lower in price the engine is good and the transmision is good .Like i said she needs a little bit of work so just send me a tell .
Thanks
Juan
Thanks
Juan
#64
Bedliner and tailgate
Originally Posted by MBBCop
Looking for a bedliner for a 1988 F250, decent shape, no holes (had one of those) Under or over rail. Also tailgate for same. Southeast Pa, Chester County.
I am not looking for cash, but I am looking for help to do the body work, sanding, bondo/rage etc. I have no experience with this at all.
Let me know what you are thinking?
#66
351w/ 302 Heads 4/s
I picked up a 351w for a truck project and like others went to the way side. what i know about it
marine engine
standard rotation
stronger botom end compared to normal car engine
better cam then in a car/truck
heads were rebuilt after 1 season, then motor was pulled
as it sits it is unopened and ready to drop in to a boat. ie: includes manifold, heat exchangers, carb flywheel/drive flang, motor mounts, dist, etc. basically you can drop it is ready to be dropped in to a boat. i did a bunch of research and to be put in to a truck , after dropping all the marine stuff, you would need the water pump and dist off of the old motor.
like to get 300$ this thing is taking up a lot of room so its got to go!
i dont really want to pull things apart but if i get a serious offer come on over and ill pull the pan and valve covers with you.
also
302 heads off of a 96 mustang gt. 40,000 miles, they were pulled to be upgraded not because of bad gaskets, complete minus rockers and pushrods. they are very clean.
100$
im located in birdsboro
marine engine
standard rotation
also
100$
#67
84 f250 for sale
i have a 1984 f250 for sale; this is my project that i just dont have the time or funds for anymore:
460 CID from a 1979 econoline e250 3/4 ton
c6 tranny
edelbrock 650cfm carb
headers
replaced cab corners and rocker panels
interior floor is coated and painted
has 2 eddie bauer seats from a 1992 explorer
i have the grill and bumper for it also
it will need a bed, powersteering pump, and heater core and a coat of paint. (dull tan and gray primer)
i have a decent amount of time and money invested in this truck and im asking 800 for it. if you have any questions send me a pm.
c6 tranny
headers
#68
marine engine
standard rotation
also
100$
marine engine
standard rotation
also
100$
1989 351w block. motor was pulled because of varying oil pressure. i started pulling the bearing caps and the crank has minor scores. rockauto.com has a crank and bearing kit for 129$. the block is complete minus heads. bored 40 over. very very clean block honning marks are still very visible.
150$
#69
1966 F-250
Way too many projects that I don't have time to finish so my slick is up for sale. See more details in the classified ad here https://www.ford-trucks.com/classifi...t/16151/cat/17 or feel free to PM me or email me. I'm looking to get $2800 for her.
#71
86 f250 parts
hi im looking to sell some of the interior parts from a parts truck i bought
i have the steering colum including the wheel and pad, the woodgrain pieces from arounf the guages/ radio most of the trim is still whole (tan) the bench seat cloth looks like it was covered from the day it was bought any parts anyone is interested in just send me a pm
im also going to sell the motor from it. its a 351W it will need valve cover gaskets and a coil im asking $75 for it
thanks, keith
thanks, keith
#72
02 parts for sale
I have a 02 hood/black excellent shape,tailgate small dent near the latch(also black), factory air box,exhaust, tail lights and a gas door all from 02 FX4. Anyone needing a part or all drop me a line.
#73
'48 F1 cab, tranny & parts
I've had it - 45 years of working on dirty old parts is enough, so I'm clearing out the rest of my projects in favor of nice, clean, new stuff. No more rust - I'm just too old!
I have a complete '48 F1 cab that's not too bad (some rust, but was inspected in PA like it is now before I took it apart). Doors are intact and latch fine. I have the original tranny, oil bath air cleaner, shifter and some other parts as well as the frame from the back of the cab forward. I welded up a rear clip with a Jaguar independent rear in it, but I haven't added it yet. Engine compartment sheet metal is also complete and intact.
I have a 283 with aluminum P'glide and the Jag rear if you want 'em - I was going to make a street rod out of this.
Come get the whole pile for $500. email or PM me through the site. Thanks!
#74
89 F350 rear
I have a rear axle assembly for an 89 F350. 10.25 ring gear,3.55 ratio, no posi. This is for a cab and chassis model and will not fit a dualie pickup.Rear is complete with drums,hubs,springs and 4 16" steel wheels.$200. Lost storage.If you are interested p/m via this site or e-mail me.I'm located about 20 miles NE of Pittsburgh.Thanks.
