Archived PA Buy/Sell/Trade Ads
Turbos for sale
I have found with the help of some friends, that i can custom make quality turbos, for any vehical. If your looking for more 4wding power, Decresing that .25 mile, or just more get-up-and-go outta the light, p.m. me, with your vehical specs (Model, Year, Engine, any mods currently on). prices start at $750. but, i will completly install the system 10 bucks an hour if you want it installed. usually labor is around 5-10 hours depending on engine type(v8's are harder to do than I 4-6's). if you want to drive a sample truck, i got one sitting in my driveway that has one on it.
dana 41 gears/wanted
looking for a ring and pinion set for a dana 41 (1977 150 2wd) probably like 4:10's preferably cheep and used. or if you have anouther rear ie: dana 44, 9", etc. id be interested in that also. for me swapping the axle is easier then the ring and pinion
I have an 83 F150 that i am putting a 400 in. ( took 460 out) The guy doing the work for me said I need a set of brackets for the frame to hold the motor mounts. All the junkyards cut them to remove the motors, so I haven't been able to find any. Could someone out there help with this?
Not sure on your year but when I did the 460 swap in my 77 I found that the 351M/400 (you may be using a bored 351W) use the same mounts as the 460 (or in my truck they did)
I myself would never replace a 460 with a 351M/400. My 351M was a dog (.5Hp per Cu") the 460 walked all over it and got about the same mpg. I found it in a old town car I did not do a rebuild just the small stuff. The best 150.00 bucks I ever spent.
Good luck
Glen
05 F-350 4x4 PSD 6Spd.
Good luck
Glen
Looking to buy new Tires
I am in the market to buy new tires for one of my trucks. I would rather buy them from someone in our group that is in the tire sales business.
No heavy lug , looking for a good all around on/off road tire.
Size 285-75-16. Make is not a factor provided the price is not over the top. All discounts accepted.
Southeast Pa
Southeast Pa
1993 f-150 for sale
I have a 93 f 150 xl. 164,000 miles on it. It has a factoy new transmission that was put in at 98,000 miles and factory new a/c system put in around the same time. has matching ARE cap and newer 31X10.50 Michelin XLT 60,000 mile tires. this is it's first winter in PA and has only a few dings from rocks on the front of the hood of rust. Asking 3,000 obo. pictures are in my gallery. I'm in shelocta, pa.
Jason
Jason
I'm looking for a used scattershield (bellhousing - Lakewood,McLeod, etc.) for an FE. Can e-mail me at nnom@enter.net. Thanks, Nick.
#28
Hello:
I recently purchased a 86 Ford F-250 HD 4x4 w/ plow and salt spreader. I am looking to sell the salt spreader. All controls. Remote start from inside cab. Control speed of feed and rotation. Full size. Will post pics soon. Starts up fine, right now just have to free up the chain feed. Cheap. Bought the 4x4 as my 85 F-350 is only 2 wheel drive.
PS. Take a look at my gallery (have tons of parts / interior exterior. Live 1 minute from a great salvage yard and close to another owned by the same person. They have always been good to me. I can help locate items you need.
Coneynew
Coneynew
#30
Does anyone have an older style 7.5 ft Meyer plow. I need the A frame that attaches to the truck. Goes between the truck and the plow blade. I will consider frame and plow blade if you need to get rid of it, but really only need the a frame. Thanks
