Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-18-2008, 11:09 PM
immastrokinnow's Avatar
immastrokinnow immastrokinnow is offline
Garage is empty, add now
immastrokinnow is starting off with a positive reputation.
biodiesel
will bio diesel (sold by gas/ fuel station) work in a powerstroke 7.3. or would the truck need to be modified at all for running it? thanks, dan
__________________
1977 f150 custom
lifted and on 35s
460 c6 combo from 84
9inch rear d44 up front
  #2 (permalink)
Old 05-18-2008, 11:26 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Biodiesel will work just fine in your 7.3. Mods are not necessary to run bio in any diesel.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 05-19-2008, 11:43 AM
sweet. there is a station near my buddies house that advertises it. not that it will sway me, but will i lose the black smoke? and should i look for anything special? thanks, dan
__________________
1977 f150 custom
lifted and on 35s
  #4 (permalink)
Old 05-20-2008, 09:21 AM
bwguardian's Avatar
bwguardian bwguardian is offline
bwguardian is starting off with a positive reputation.
You will loose the black smoke...it burns cleaner. Wing the truck starting with 5 gallons bio to a tank, then 10 or 15 gallons to the next tank before running it straight or you will work things loose in the tank all at once and clog fuel filters (always carry and extra one just in case).
__________________
2000 F-350 4x4 CC srw - Tranny/Converter tricked, SCM, Walker BTM, K&N, front end picked up 2"
2000 Excursion Limited 4x2 - SCM, Banks muffler, K&N, nice stereo (400w for the wife), TV's/DVD (for the little ones)
2001 F-250 4x2 SC - SCM, Walker BTM, K&N
2001 F-550 6x4 RC - SCM, Walker BTM, K&N
1997 F-250 4x2 SC
  #5 (permalink)
Old 05-20-2008, 02:06 PM
97squarebody 97squarebody is offline
97squarebody is starting off with a positive reputation.
The question I have involves temperature problems. When running well made Bio, what are the temp restrictions? I know that with standard veggy oil, there are some real problems, you need heaters even in warm weather. What are the cold weather limits on b100 before you have to modify a stock truck?
__________________
CL
So, who hired Wile E. Coyote as a consultant?
1997 F-250 4WD W/460 & a manual
2008 Explorer Sport trac
2003 SVT Focus (The Go-Cart)
1967 Mustang Coupe W/351W & a 3spd. (Temporarily Retired)
  #6 (permalink)
Old 05-20-2008, 05:01 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
The solution to cold weather BD use is simple run Bio/Dino blends. The two can be splash mixed, just pump it into your tank.
The cloud point of BioDiesel depends on the source of the oil, for example Soy based BD will cloud at a higher temp than Canola.
Unless you make your own you will not know the oil source so start blending about 40 degrees (B80 or B90) and gradually increase the percentage of Dino as expected temps drop. You can get an idea of cloud point of the fuel you are using by simply putting a sample in your freezer and taking its temp every few minutes untill it starts to cloud or gel.
The problem with running cold VO has to do with coking injectors and rings which will destroy your engine. It is not the same as the clouding/gelling of BD which will go away once everything warms up.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #7 (permalink)
Old 05-20-2008, 10:58 PM
Quote:
i usually have a spare at the house, so i could just throw it in the truck. and the tank is new 2k miles TOPS. and the rear tank will have to be replaced before anything goes in it. but i will ween the truck onto it still.
__________________
1977 f150 custom
lifted and on 35s
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
