Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-18-2008, 09:42 PM
KyleG KyleG is offline
Garage is empty, add now
KyleG is starting off with a positive reputation.
Question I think I need some help with making fuel...
Ok, I got legit plans from guy I know who makes fuel from waste veggie oil. He runs it in a 2001 Ford Excursion with a 7.3 and it runs good, he's got 40,000 miles on it with the veggie oil. I tried to make it with his same plans, but it didnt run so good in my truck, which is an 86' F-250 with a turbo 6.9L. Here is how I make it...I get oil from a local resteraunt, that I work at, about 40 gallon a week, I have a filter setup in my garage that i run it through next. It is 2 pumps that forces the oil through a 20 micron hydrolic filter then a 5 micron carbon filter, I filter the oil twice. The mix calls for 10% Kerosene and 5% gasoline and a certain amount of 2 different additives. Now I ran this same mix in my truck for about 500 miles, now it wont run on it. I understand that my truck is older and has less fuel heaters and such, but I think if I double the amount of the ingredients it calls for each batch, and filter it more, I can run it succesfully. What do you guys think, try that, or actually make bio-diesel with the methanol and the lye?
  #2 (permalink)
Old 05-19-2008, 08:30 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Make BioDiesel
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 05-19-2008, 09:17 AM
Wookie35 Wookie35 is offline
Wookie35 is starting off with a positive reputation.
replace your filters and then make biodiesel
  #4 (permalink)
Old 05-19-2008, 09:52 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Make Biodiesel!
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #5 (permalink)
Old 05-19-2008, 07:02 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
If you don't want to make Biodiesel you need to convert to a heated WVO system. It will cost you between $1000 if you do it your self or $4000 if you have some one make and install it for you.
WVO works if done right..... If you do it wrong in about 500 hrs of running you will need a new motor.
Or you can do what some very smart people have already said and make Biodiesel.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
