Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 05-18-2008, 08:35 PM
zed326 zed326 is offline
Garage is empty, add now
zed326 is starting off with a positive reputation.
Unhappy 98 expedition NO HEAT??
i just did my thermostat because the dang truck had no heat and now i ran the thing and it still has no heat? could this be the water pump? is it a hard job?
  #2 (permalink)
Old 05-18-2008, 08:39 PM
AtlPikMan AtlPikMan is offline
AtlPikMan is starting off with a positive reputation.
Naaa! Wouldnt be the warter pump. My guess would be the Heater Core. Sorry i dont have much knowledge repairing the Problamo....
  #3 (permalink)
Old 05-18-2008, 09:36 PM
projectSHO89 projectSHO89 is offline
projectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to all
Might be a simple as a stripped temperature control ****.
You need to do some diagnostic work before you pick up another wrench.
Steve
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: https://www.fleet.ford.com/maintenan...ls/default.asp
“It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
  #4 (permalink)
Old 05-19-2008, 06:17 AM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
Do both heater hoses feel hot? If they do you might have a problem with the blend door inside.
__________________
2013 Explorer Limited
87 Ranger, XLT
  #5 (permalink)
Old 05-19-2008, 12:45 PM
sbclemens sbclemens is offline
sbclemens is starting off with a positive reputation.
Make sure you have bled all the air out of the system.
__________________
98 Expy XLT 4x4 5.4L
  #6 (permalink)
Old 05-19-2008, 01:47 PM
sysman_rick sysman_rick is offline
sysman_rick is starting off with a positive reputation.
Post
After you have eliminated the simple & obvious,search on blend door problems. It's a gotcha problem.
__________________
F-150 2005 KR 5.4 L Supercrew
Mods:
Magnaflow SI/DO exhaust system;Leer bed cap;Bed Rug bed liner;Volant cold air box;Edge Evolution tuner;Magellan Integrated Nav System;Silver Star Headlight& Fogs;Fire & Ice led bar;White Knight rear bumper illumination.
  #7 (permalink)
Old 05-19-2008, 07:37 PM
blend door??
what is it and where is it? never heard this one before???
  #8 (permalink)
Old 05-19-2008, 09:32 PM
Do a search on blend doors. You will get plenty of information on how to diagnose the problem and what is involved in the repair.
__________________
  #9 (permalink)
Old 12-17-2009, 01:21 PM
f2504x4man f2504x4man is offline
f2504x4man is starting off with a positive reputation.
I have the same problem on the same vehicle. Could both blend doors for the front and rear go out at the same time? I havn't checked the blend doors because both the front and rear heat doesn't work (switches and motors work). The upper radiator hose will not get hot. I've pressure tested the system, checked the fan clutch, thermostat,cap and flushed out and bled the cooling system . Both heater hoses get warm but not really hot. I'm stumped
  #10 (permalink)
Old 12-19-2009, 09:36 AM
steeler82 steeler82 is offline
steeler82 is starting off with a positive reputation.
f2504x4man, I had same problem last winter 2008...2000 Expy no heat front or back. I changed thermostat, flushed heater core and it started putting out warm heat enough to get thru winter. Now 2009, it's back to original state...no heat front/back. I'm thinking of changing water pump.
Did you figure out your problem?
Thanks.
  #11 (permalink)
Old 12-19-2009, 10:10 AM
madsonp's Avatar
madsonp madsonp is offline
2012 Ford F-250
madsonp is gaining momentum as a positive member of FTE.madsonp is gaining momentum as a positive member of FTE.
Thanks.
If your water pump was bad you'd have a lot more problems. Given what you've done in the past, I'd say your heater cores are plugged again. Once these plug off a flush may only give you a temporary fix before they plug up again like you're seeing. I think you'd be throwing your money away on a pump and still be stuck with the same problem.
__________________
2012 F-250 Lariat 6.2 L 4x4 (The Beast)
99 (Sold) & 97 Expedition EB 4x4 5.4L(Wife's)
77 E-250 4x4 Van 460ci (Sold) & 76 E-350 Motorhome 460ci (Need to sell)
42 Ford 9N Tractor (old pig)
  #12 (permalink)
Old 12-19-2009, 12:17 PM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
a few thoughts, upper rad hose should get hot if it doesn't you prob have an open tstat. feel both heater hoses at the firewall if they are both hot your core is prob fine. you can go to heatertreater.net and learn all about the blenddoor. some of these motors have heater control valves that are inline with the heater hoses, they can leak and or go bad. I would only use motorcraft tstat. In theary the fins can break off the waterpump dimishing the coolant flow but as posted earlier you prob would have had others issue like overheating in the summer. IT IS VERY IMPORTANT TO GET ALL THE AIR OUT OF THE SYSTEM AFTER CHANGING TSTATS ETD,. AIR BUBBLES CAN CAUSE A LACK OF HEAT
__________________
1999 Reg Cab, Styleside, 2.5L, 2WD, M5OD, RABS, no A/C, MFG. Date 12/98, Gatorback belt, Autolite DP plugs/wires, Fluids and Maintenance done regularly, 141k as of 5/2/2012
Unless you have gone to the control panel and created a detailed signature of your truck similar to mine you are not doing all you can to solve YOUR PROBLEM!
Tags
98, back, bleed, coolant, cooling, expadion, expedition, expeditions, ford, front, heat, lincoln, navigator, pressure, rear, system, truck, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
