Truck died AGAIN!!!
Truck died AGAIN!!!
Well I was drivin down a main road, truck died while driving, I coasted off to a parkin lot and got towed home. Heres the symptoms, but I think I'm hot onto the problem.
My battery light is not flashing, but pulsing as well as volt meter.
No WTS light.
If I turn the key 3/4 way to start, and go under the hood, I can hear something shortin out. Wires to the glow plugs???
No WTS light.
Received 3,675 Likes
on
red/lt green goes from fuse #22 (hot in run or start) to the latching coil of the GPR. the circuit is completed through the purple/ orange wire to the #101 pin of the powertrain control module, where the module gives it a ground to complete the circuit. you could have a short in the ppl/org wire, or a false signal from the pcm.
I was just out playin around wtih it, didnt get too far. If i turn the key to start, and go under the hood, I hear loud clickin noises, comin from the gpr and the relay thats in the power distribution box (second one over from drivers fender). Its just a PITA tryin to trace the wires back, find the short.
I tested all of them just to see. THe small terminals are readin open. However if i take the small relay out int he black distribution box, it still makes the ticking/shortin sound. does the little relay feed the gpr relay or is it the other way around????
