Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-18-2008, 01:37 PM
Still Smoking's Avatar
Still Smoking is starting off with a positive reputation.
whats the difference
what is the difference between the sct x3 and the sct live wire. i found a website i can get either one and a cold air intake. there are other brands the x3 would be 500 with cold air intake and for 150 more i can get the live wire with the intake. whats is the difference between the two? if any? i want it for increased mpg not to bad on the throttle and for towing thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-18-2008, 02:30 PM
tex25025's Avatar
tex25025 is gaining momentum as a positive member of FTE.tex25025 is gaining momentum as a positive member of FTE.
Well they both have had their quirks, I don't know if they have been worked out, but I do know with regard to people that bought them for 6.0s and 6.4s they have had issues with both products. They both hold custom or canned tunes, however the livewire is also a set of digital gauges that plug into the OBD-II port(which I do have my issues with, but I won't get into them on this post) for the majority of the readings. In all honesty, you don't want to get this type of stuff for mpg gains, you want to get it to make your truck perform better for you and if you pick up some mpgs then that's a perk, don't expect gains in regard to mpg. If your getting this for a 6.4 or a 6.0 diesel then I would want as SCT and other companies are developing new(er) products that hopefully should be better then these.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #3 (permalink)
Old 05-18-2008, 02:45 PM
well its for a 2004 150 with the 5.4 the website has these kits and you can pick between the diablo superchip flashpaq superchip cortex programer add on 100 or the sct one i mentioned and you can pick between the s & e intake or the k&n generation II or the k&n 77 series which i chrome u add on 50 so i was kinda leaning towards one of the sct and the 77 series
  #4 (permalink)
Old 05-18-2008, 03:21 PM
tex25025's Avatar
Oh it's for a 5.4 ok. Which ever one you go with make sure that it allows custom tuning(rather you have to use a tuner or get the software and do it yourself) that will help you out the most with towing and it will give you the greatest chance of gaining mpgs(although don't think you'll automatically get it). Tuner's really don't help gas engines out as much as they do diesels, but with custom tuning it should help you out some.
__________________
Fluidampner
Headstuds
FASS 150/180
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
