Valve train lubrication problem on 61 292
Old 01-05-2002, 11:10 PM
L0ngJ0hn's Avatar
L0ngJ0hn
L0ngJ0hn is offline
Post Valve train lubrication problem on 61 292
Hello,
I've got a 292 with poor oil circulation to the passenger side head.
We just got this truck and don't plan on tearing it down immediately.
Isn't there a temporary fix involving an "external oil line kit" for this problem? I know it is ugly but it would get it going again.
All help greatfully appreciated !
Thanks,
LongJohn
Old 01-09-2002, 06:38 PM
darkman's Avatar
darkman
darkman is offline
I've seen these kits on e-Bay for bidding. Try searches for y-block and I think you'll eventually find one. Maybe someone else knows where you could buy one. I think you could make one if you try!
Charles in Pensacola
Old 01-09-2002, 07:13 PM
L0ngJ0hn's Avatar
L0ngJ0hn
L0ngJ0hn is offline
Thanks for the advice. I am already looking on eBay.
I am also trying heavier weight oil to raise the oil pressure too.
(20W-50). I get approx. 20psi at idle when hot. Wish I had more
All the Best,
L0ngJ0hn
Old 01-30-2002, 06:58 PM
w6ytg's Avatar
w6ytg
w6ytg is offline
LongJohn:
You might want to consider pinching shut the rocker arm overflow tubes to increase the oil pressure within the rocker arm shaft. This will deliver more oil to the rocker arms. Refer to Eickman's book "Ford Y-Block", page 36.
As you are probably aware, the Y-block's Achille's Heel was insufficient lubrication in the rocker arm assemblies. I have seen an overhead oiler kit for sale recently on E-bay. Good luck.
David
Old 01-31-2002, 05:27 PM
rogerf100's Avatar
rogerf100
rogerf100 is offline
The outside oiler kit included a hollow stud in the location of the original stud for the valve cover. A copper tube was plumbed from the oil gallery on the drivers side of the block using a T with the oil pressure sender.
I disassembled a 292 about 18 months ago that had one of these kits installed. If you want I can look thru my parts to see if I still have them. It could keep you going until you tear down for a rebuild.
rogerf100
Old 01-31-2002, 05:55 PM
L0ngJ0hn's Avatar
L0ngJ0hn
L0ngJ0hn is offline
Hey Roger,
Thanks for the offer, but I picked up a kit off of eBay last weekend. The kit was complete and is already in service. Piece of cake to install. I now have an optional oil leak installed !
Old 02-04-2002, 11:29 AM
46fordtruck's Avatar
46fordtruck
46fordtruck is online now
mcmurb
01-12-2015 05:53 PM
RhondaBruce
03-30-2013 09:48 PM
truckman87
06-09-2012 02:04 PM
EricW.
The Next Generation
13
06-08-2008 11:34 PM
Mgles50117
09-25-2001 11:15 PM
Quick Reply: Valve train lubrication problem on 61 292
