What condition are the connections on the relay like?
Do you have the black ground wire hooked to a good ground with a clean connection?
Look at the connector near the dip stick where the engine harness plugs into the chassis harness.
The two large tan wires at one end of that connector are the poswer supply from the battery to the relay.
Are the connectors in that connector in good condition?
Those same tan wires should hook up to the battery terminal of the starter relay on the fender.
Is that connection in good shape?
What condition is the wire from the starter relay to the battery in?
Any connection between the battery and the glow plugs that has any corrosion in it will alter the voltage supplied to the glow plugs.
The solid state controller will not function propperly without propper voltage, and since the controller uses resistance feed back to time the cycle, any corrosion in the connections will alter the cycle time.
When you say you replaced the relay, did you replace the entire unit with the controller under it, or did you just replace the relay?
