Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 11:48 PM
95Z71 is starting off with a positive reputation.
changing rear differential fluid
I pick up 4 quarts of the 75W-140, i was looking at Guzzle's website and it calls for Ford's XL-3 friction modifier. The gear oil i bought says limited slip and it's synthetic, but my question is will i need to add the friction modifier?
Thanks
__________________
2003 7.3L, FX4 CC LWB F-350 Lariat, 4in lift, DP-Tuner, ATS housing, Di-pricol Optix gauges, BTS valvebody,6637, 4in exhaust
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-17-2008, 11:50 PM
1996pwrstrk's Avatar
Ar Chapter Ldr
1996pwrstrk has a good reputation on FTE.1996pwrstrk has a good reputation on FTE.1996pwrstrk has a good reputation on FTE.
What kind did you buy Mike ?
__________________
Dave
1999.5 F350 XLT,cc,drw,4X4,a pair of levers,4:10 LS
6637 mod, 4"MBRP cool duals,2 pos chip, ss hpx,ITP pre-pump with holley red pump ,140 V IDM , WW, EBPV deleted,AIH deleted, Autometer gauges
Join the Arkansas Chapter Here
  #3 (permalink)
Old 05-17-2008, 11:55 PM
Hey Dave, how's it going? I got Valvoline, they had some friction modifier, but it wasn't the kind that said XL-3 though
__________________
  #4 (permalink)
Old 05-17-2008, 11:59 PM
distortedcloud's Avatar
distortedcloud is starting off with a positive reputation.
Sorry to thread hi-jack, but will changing diff fluid increase mileage?
__________________
2000 F250 Lariat EC-SB, 6637, Straight pipe, Gauges, DP Tuner(no start, stock, 60tow, 80econo, 120race, 140smoke)
  #5 (permalink)
Old 05-18-2008, 12:05 AM
Ar Chapter Ldr
If it says it's for LS I would try it without modifier the Royal Purple I use in mine doesn't need any modifier. Got tired of only spinning one tire did ya?
__________________
Dave
  #6 (permalink)
Old 05-18-2008, 12:07 AM
Ar Chapter Ldr
Quote:
Don't know about increasing your mileage but it will increase the life of your diff.
__________________
Dave
  #7 (permalink)
Old 05-18-2008, 12:23 AM
Ok i will try it out and see how it goes without the modifier. I take it that it doesn't have to be the CL-3 from Ford? Yep still just one tire, lol
distortedcloud: no worries on hijacking.
__________________
  #8 (permalink)
Old 05-18-2008, 12:26 AM
Ar Chapter Ldr
Ya Mike if it chatters you can always add a few ounces of modifier later, you don't want to add to much or you will end up the way you are now with a one wheel peel.
__________________
Dave
  #9 (permalink)
Old 05-18-2008, 12:36 AM
Cool Dave, so that should do the trick then. Thanks I didn't know that syn gear oil was so expensive; little over 13.00 a quart.
__________________
  #10 (permalink)
Old 05-18-2008, 12:48 AM
camodown is starting off with a positive reputation.
Just don't spill any friction modifier on yourself...it smells horrible and doesn't wash out...not that I ever have...haha
  #11 (permalink)
Old 05-18-2008, 01:04 AM
crosbo's Avatar
crosbo is starting off with a positive reputation.
KY doesn't wash out?
__________________
__________________
Tom
'00 CC F250 4x4 Auto 4" Magnaflow, S&B Cold Air Intake, AIH, Edge A2/Juice, HPX, Pre-pump, In-Tank, CCK, 203 Thermostat, Air Horns, XM Satellite Radio, 2" lift, 315's, Trucool 4739, '06 Grill and emblem upgrades, RealTree skins and a hot babe in the passenger seat!
  #12 (permalink)
Old 05-18-2008, 10:50 AM
King0581 is starting off with a positive reputation.
Ok so changing the type of fluid will help the limited slip work better? What kinda fluid are you guys using?
__________________
Lee '03 F250 supercab 4x4, 7.3,6 speed. Edge Evo 2, 6637 filter, CCV mod with catch can, shimmed FPR, EBPV brake, King style Zoodad mod, Cold AC mod, wicked wheel, Hutch and Harpoon, prepump filter. Leveling kit, 305/70/16's. 203* stat, coolant bypass filter. 4" st stl MBRP. Upgraded front end goodies in the mail(still waiting on these)
  #13 (permalink)
Old 05-18-2008, 10:58 AM
zack7.3's Avatar
On Vacation
zack7.3 is starting off with a positive reputation.
I am using mobil 1 synthentic, and I paid like $16.00 a quart for it.
__________________
ZACK
99.5 F250 7.3 PSD 4x4 CC LWB, 6637, Foil Delete, MBRP 4" dual smokers stacks, TS Chip, stock, high idle, 50hp, 70hp, 100hp, 140 smoke, optima red top batteries, 2.7" leveling spring pack, 35x12.5x16.5 BFG AT, Cobra 148 GTL.
PAA Member # 36
  #14 (permalink)
Old 05-18-2008, 11:06 AM
Duh!! Makes since now. Changing the fluid and adding less of the limited slip lub makes more since now. My fingers got faster then my brain. Anyways is the dealer the only place to get the additive for the limited slip?
__________________
  #15 (permalink)
Old 05-18-2008, 11:16 AM
Tenn01PSD350's Avatar
Miller Brewing Co
Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.
Quote:
Nothing but a rebuild will fix a diff that is worn out. Now if the fluid is going bad, replacing that can bring her back to life. Besides, if you have any kinda mileage on the truck, it is a good idea.
I used RP and it didn't need any modifier. Whatever you choose, it must be synthetic and any modifier must be compatible.
Now is a good time to replace the cover with the newer finned one. I sanded and painted the stocker as I did mine right about the time the new covers were coming out. PITA. This procedure is covered in guzzles page.
A few points, my diff had about 60k on it and lots of crud. I cleaned it out with lots of brake parts cleaner. Also, pull the VSS sensor and clean the fuzz/crud off of that. That hole makes a good fill hole too as it is on top. There are a few pics in my gallery of what I am talking about.
__________________
Pushing the PMRs.
Mike
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
