Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 11:07 PM
ngng's Avatar
ngng is starting off with a positive reputation.
where do you guys mount your brake controllers?
I'm going to install the Tekonsha P3 sometime next week, when I had it in my Jeep I had it mounted under the dash. Is this what you guys do most of the time?
Finally, anybody have photo of what the brake controller plug looks like on the Ford looks like? I want to confirm the truck is prewired.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-17-2008, 11:20 PM
jhand124's Avatar
jhand124 is gaining momentum as a positive member of FTE.
I mounted mine under the dash in just about the only spot there is, its like it was made to be there. Kinda off to the right of the drivers leg under left of center.
I will almost guarantee that your truck is prewired, sorry no photo
__________________
Jason
Early '99, F350, 4" ex, AFE II intake w/ Pete's cover, ISSPRO gauges,TSI built trans, DP Tuner, CCV, ITP OB, EBPV brake w/ T/C lock & LED Indicator, ZOODAD, stancor GPR. GP LED Indicator, 203* Stat & Billet Housing, True cool max 4739, CCK, S.S. HPX. 3:73's, Schaeffer's 9000. 210000 on the clock
On work bench: Nothing
  #3 (permalink)
Old 05-17-2008, 11:28 PM
ngng's Avatar
I saw that spot when I was looking up under the dash looks like that is where it'll go. Good to hear it 's prewired...I'm going to spend the 15$ and pick up that prewired pigtail!
  #4 (permalink)
Old 05-18-2008, 05:33 AM
RogueSpear2023's Avatar
You should be a
RogueSpear2023 is starting off with a positive reputation.
I mounted mine right above where the manual shift lever is for 4wd.
__________________
1999.5 F-350 SC SB 4x4 XLT SRW
7.3L PSD / Auto / 3.73 LS
Muffler Delete, 6637 Mod, Zoodad, CCV mod, Stancor GPR mod
Best truck I've ever owned
"It's better to have it, and not need it; than need it, and not have it."
"You can't legislate stupidity"
-Max
  #5 (permalink)
Old 05-18-2008, 10:37 AM
wlihntr's Avatar
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
__________________
2001 Powerstroke, CC,SB,Lariat,Auto,4X4
Mods. in Gallery
2007 Lincoln MKZ awd
its good to have an open mind...but not so open that your brains fall out
  #6 (permalink)
Old 05-18-2008, 10:44 AM
jhand124's Avatar
Quote:
Originally Posted by wlihntr View Post
Ditto.............
__________________
Jason
  #7 (permalink)
Old 05-18-2008, 11:09 AM
GEugeneS is starting off with a positive reputation.
I was just about ready to start cutting wires when I saw this pigtail up in the dash on my '02 which had the same number and color of wires as the "universal" pigtail Tekonsha gave me. When I ordered it they required info on my truck. Why in hell they don't give you the one that just plugs in is beyond me. So I ordered the plug in one and trashed the one that came with it. What a waste!
__________________
Gary,
2002 F350 Lariat PSD Crew Cab Dually, Edge Evo EEF-1120, B&W Turnover Ball gooseneck hitch, Tekonsha brake controller
  #8 (permalink)
Old 05-18-2008, 11:13 AM
By the way, ditto on the controller location as Jason and Wlihntr.
__________________
Gary,
  #9 (permalink)
Old 05-18-2008, 12:05 PM
sawfish99 is starting off with a positive reputation.
Mine is by my left knee, under the headlight switch. My CB is where the wlihntr showed his controller. The only problem I have with it on the left is after my wife drives and doesn't move the seat back, my knee hits it on the way into the seet.
__________________
02 F-350 7.3L CC/LB/SRW
6637 mod, CCV mod, 203 Thermostat, bypass coolant filter, backup fog lights, Diablosport Predator
  #10 (permalink)
Old 05-18-2008, 12:22 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3 is starting off with a positive reputation.
same problem as sawfish... I have my CB where Jason has his. I dont mind it there as as i can reach and see it with no problems, just not as convenient when you get into the truck
__________________
WILL PAA #30
2001 F250 Auto EC LB 4x4
DP (S, High Idle 1300, Lope Idle, 60T, 60D, 80E, 120R, 140 Agg), Turbonetics BB 1.00 housing, 4" Hog straight pipe, OBA, Zoodad, 6637 w/ Pete's cover, CCV, Superlift lvl., 35" BFG AT's, Recon triple disk TC, Autometer NV's (trans, pyro, boost), train horns, billet grille, International badges
  #11 (permalink)
Old 05-18-2008, 12:31 PM
trike1946 is gaining momentum as a positive member of FTE.trike1946 is gaining momentum as a positive member of FTE.
Mine is the same as RogueSpear.
__________________
Bob
96 E350, 7.3 PSD, Auto
97 E Super Duty, 7.3 PSD, Auto
90 E350, 7.3 IDI Diesel, Auto
99 Expedition 4.6, 4x4
2001 F250 SD 7.3, 4x4, CC, LB, SRW, Auto
2001 F350 SD 7.3, 4x4, CC, LB, DRW, Auto
  #12 (permalink)
Old 05-18-2008, 01:45 PM
twags6's Avatar
PAA Member #7 and FTE
twags6 is gaining momentum as a positive member of FTE.
Are there any fuses you have to add after you put the controller in? I have two maxi fuses under the hood that are labeled for trailer towing and there arent fuses installed. Its 16 (trailer tow batt charge) and 28 (trailer tow electronic brake controller).
EDIT: There are also two empty relay sockets in the little box attached to the fuse box. Are these the trailer charging relays and reverse light relays that are listed in the manual.
__________________
Trevor
01 F-350 CC 8ft bed SRW 7.3L a/t.
straight piped, 3 pillar gauge pod (egt, boost, trans temp), hutch mod, 6637, zoodad and many more to come.
gotta feed the PMS
PAA Member #7
  #13 (permalink)
Old 05-18-2008, 02:11 PM
I didn't remember any fuses on the install so I looked at the wiring diagram that came with the Tekonsha. No fuses! guess it shares a fuse with something else or it's on the F350's stock fuse block. I'll go look but not today, it's already over 100 and it's Miller time.
It must be fused. Ford wouldn't have a standard pigtail set up for it and not have it fused.
__________________
Gary,
  #14 (permalink)
Old 05-18-2008, 02:25 PM
dadsgreenpsd's Avatar
dadsgreenpsd is starting off with a positive reputation.
Mine is in the little cubby above the 4wd shifter. I drilled a hole in the back of the cubby for the wiring, and pushed a plastic soda bottle cap in on top of it to hold it in place. Yeah, I know it's redneck, but it fit perfectly and hasn't moved in 3 years. I couldn't find any other use for the cubby, everything else I put in there falls out on the rough roads around here...
__________________
Jon
PAA#
2001 F250 ext cab shortbox 4WD, 5-15K, Straight piped, Hutched, 6637, upgraded clutch, shaved intercooler tube
2005 E350 Super Club Wagon 15 Pass. 5.4 party wagon
Visit me at Trailmonkeys.org
and blueskyme.com
  #15 (permalink)
Old 05-18-2008, 02:44 PM
cangim's Avatar
cangim is starting off with a positive reputation.
What you have listed should be all that you need. and yes the two empty sockets are for trailer charging and reverse lights. Some people don't like the relayed 12V charge. I guess on utility trailers and such the lights all run from the truck, no battery like on an RV. For that, you could simply make a jumper with male spade connectors, 10 awg wire or so, and plug it in. Each to their own. Me, i'd forget about it and end up with dead batteries becuase I left a light on in the trailer.
__________________
Give your truck what it wants; a shot of DP-Tuner
-Mike
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
