Highboy lift kits - Page 3 - Ford Truck Enthusiasts Forums
Highboy lift kits
  #31
Old 04-03-2009, 11:58 PM
71hightoy's Avatar
71hightoy 71hightoy is offline
71hightoy is starting off with a positive reputation.
Quote:
Originally Posted by 75F350 View Post
Welcome to the site.
This is a pretty old thread, and perhaps some new stuff has come in to play, but after reading a little most is still pretty accurate.
At any rate, as long as you have to install the rear hanger, you might as well install it where you want regardless of which spring you have. If you perform the shackle flip, you will not be using the stock mounting holes anyway. In order to achieve the proper shackle angle, this configuration will require that the pivot be located further foward anyway, so get one up there, and set some weight on the truck and verify the angle. It sounds as though a previous owner started something that is not exactly stock so providing you with the magic answer will be close to impossible. Too many variables here, and maybe the previous owner used a different style spring. Fortunately the rear springs are pretty easy to set up.
what you said about the previous owner is exactly correct. the forword rear spring hanger is bolted exactly where the stock one was (ofcourse it has different holes) regardless however im curious how far approx* i will need to move the back rear spring hanger forward. because right now i can slip the front leaf spring bolt in raise the leaf up and the bolt hole on the leaf is about 4 1/2-5" away from bolting up. even though i still need to drop the rear hanger down i took a strait edge allowing me to see how close it would be if the mount was lower and i still only get about 1/2 or so closer to the hanger. my other question is regaring the smaller spring. they have a ford stamp on the bottom so im wondering if maybe they started out as 52" springs (thats just what i measured of stock 76' highboy springs) and were rearched or something because now they are 47" from center bolt eye to bolt eye (something to think about) and if i bring the back hanger forward will my axel still be centered in the wheel well not a big deal just had to ask. thanks for the help
  #32
Old 04-04-2009, 11:59 AM
75F350's Avatar
75F350 75F350 is offline
75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all
I have no problem saying that I am an idiot and am a little confuesd at this point. Maybe you have a pic or two to help explain. I am sure that you worded everything correctly, but again, I am a numbskull.
You say that your current springs are way too short? This is a problem. SInce the axle alignment pin does not change, the axle will stay located properly. This should not be a problem. It is very difficult to say exactly where the rear hanger has to be located, since each and every spring has different rates. What I mean by this is that a spring will become flat when weight is applied, and as it flattens out it gets longer. This will have an effect on the final location of the hanger. What you have to do is locate the hanger temproarrily, and rest the vehicle weighton the springs. Then use an angle finder to verify the desired shackle angle. When it is not correct, make adjustments to the hangerlocation and do it all over again.
Yes, this is a time consuming deal, but it is what has to be done. I often use this time to cycle the suspension as well.
  #33
Old 04-05-2009, 12:20 AM
71hightoy's Avatar
ok this is the forward rear spring hanger. its of a 2wd ford and as you can see it drops the spring mount much lower.
ddd
ok so as i was saying. when i bolt up the spring to the forward mount this is what i end up with in the back-back.. its almost 5 inches away. is moving the hanger that far forward a good idea. seems like that would leave room for alot to go wrong :P.. maybe im just a newbEE. lol
  #34
Old 04-05-2009, 12:27 AM
71hightoy's Avatar
ddd
  #35
Old 04-06-2009, 01:34 AM
75F350's Avatar
I would actually be installing a shackle on that and put some weight on it. As you place weight on the spring, it will flatten out, and as it flattens, the shackle will move to a more vertical position.
The unkown variable here is hpw far it will move once the weight is applied.
With that front hanger, I would bee concerned about the pinion angle being to positive (pointed down).
If this truck is lifted, this might be a great candidate for a shackle flip in the back. ANother hanger like the one used up front would provide some mad lift with the stock spring.
Either way you are gonna have to install a shackle on that and put some weight on it to see what kind of angle you end up with.
Then you can determine without guessing.
  #36
Old 04-08-2009, 07:21 PM
71hightoy's Avatar
oh man you were right. by moving the new rear hanger 2 1/2" forward and adding a shackle i can now use my 6" lift springs. this is quite insane though. this flip netted me about 5-5 1/2" of lift and with my 6" springs and 2" body this truck is going to set very high. thank you for all the help. hope to post pics of it soon
  #37
Old 02-07-2014, 07:36 AM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Subscribed to have in my book of ideas......old and dead, hope I do not wake up the zombies.
Procomp 22415 lift spring Suzuki357 Excursion - King of SUVs 20 03-09-2015 07:35 AM
Leaf spring lift measurement arkredneck 1994.5 - 1997 7.3L Power Stroke Diesel 28 10-28-2014 07:45 AM
Need to buy Leaf Springs - 2004 F350 4WD rayezra 6.0L Power Stroke Diesel 13 05-17-2014 08:08 AM
4" leaf spring lift with best ride? big specht 1999 to 2016 Super Duty 2 04-16-2014 09:39 PM
bronco II rear leaf springs big meat Bronco II 11 03-06-2014 10:35 AM
Tags
1972, 1973, 1979, 70, body, boy, cheap, f250, ford, high, highboy, kit, kits, lift, np205, reindexing, spring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
