Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 10:22 PM
IceboxFX's Avatar
IceboxFX is starting off with a positive reputation.
injector rebuild question.
truck is running not-so-good and i think i have narrowed it down to the injector o-rings. would it be worth it/ a good idea to replace only the outer o-rings? if so, could anybody point me in the right direction to but the replacement o-rings?
thank you guys,
brian
__________________
97 F-250 Ex Cab 4x4 7.3 PSD
Superchip
Green air intake
4"MBRP w/DP
08 Diff Cover
HPX
CCV
-For Sale-
Truck pics
  #2 (permalink)
Old 05-17-2008, 10:30 PM
Robbgt's Avatar
Robbgt is gaining momentum as a positive member of FTE.
set of 8 on ebay right now
eBay Motors: Set of eight powerstroke 7.3 7.3L injector oring kits (item 350060296984 end time May-24-08 15:01:13 PDT)
If you haven't pulled the injectors before let me know and I'll scan my full directions and send them to you
also I'm not sure the outer ones have a hole lot to do with running characteristics, some leak and you get a bit of blue smoke at startup. May be looking at an injector rebuild? I changed my outer O-rings from blue smoke issue. No more blue smoke but truck still runs the same,
-Robb
__________________
97 F-350 XLT 4x4 PSD, E40D, 3.55's, 153K, 6637, 140V IDM, HPX, FPR Shim, Hotfoot, Tymar DP, Dual Exhaust, T/C Lockup mod, new GP's, Stancor GPR.
>>FOR SALE: FTE Classifieds<<
  #3 (permalink)
Old 05-17-2008, 10:32 PM
helifixer's Avatar
Jake's Dad, Arizona CL
helifixer has a great reputation on FTE.helifixer has a great reputation on FTE.helifixer has a great reputation on FTE.helifixer has a great reputation on FTE.helifixer has a great reputation on FTE.
Southwest Diesel in Phoenix, they were the best deal I found.
__________________
the little people who live behind my eyes and scream directly at my brain told me to tell you HELLO
http://arizonafordtrucks.myphotoalbum.com/
Heli kop ter! Noun! a helicopter is nothing but a oil leak surrounded by a rotating mass of metal fatigue
aka snl #36
  #4 (permalink)
Old 05-17-2008, 10:44 PM
IceboxFX's Avatar
helifixer, thats a pretty good price you found.
robb, i pulled them on my buddy's truck before and i helped him rebuild two of them. do your directions include rebuilding them, or just pulling? thanks for the link for the set on ebay, good price!
also, would the DIY kit for stage 1's minus getting the pistons be the same thing? the diy kit comes with the armature screws and a injector tool aswell. don't know if the armature screws are worth replacing tho.
__________________
Superchip
Green air intake
4"MBRP w/DP
08 Diff Cover
HPX
CCV
-For Sale-
Truck pics
  #5 (permalink)
Old 05-17-2008, 10:51 PM
Robbgt's Avatar
Just pulling them and replacing external O-rings and GP's. Not rebuilding them. I haven't had my actual injectors apart, so I can't answer your other question. wait for a few more guys to chime in. DIY-Injectors.com Give him a ring. I'm sure he could sell you a kit thats minus stage 1's.
-Robb
__________________
  #6 (permalink)
Old 05-18-2008, 02:39 AM
RubberDuck's Avatar
Death Row Inmate #1
RubberDuck has a good reputation on FTE.RubberDuck has a good reputation on FTE.RubberDuck has a good reputation on FTE.
Quote:
The DIY Stage 1 kit without the pistons is a rebuild kit for all 8 injectors. The piston is what makes the stage 1 majic. The armature screws are worth replacing because the stock one is funky and strips easily, but not nessisary. And I would HIGHLY recomend a parts pack because if you do all 8, you are bound to break atleast 1 dowl pin. And it's well worth the money to have the extra setup in case. Hope that helps.
__________________
RubberDuck
1995 F350 Crew Cab 4x4 dually
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
DP Tuner 2 pos. w/ custom switch
Hot Pedal
Gear Vendors OD
Good bye No.3 I'll miss you.
RIP #17
  #7 (permalink)
Old 05-18-2008, 05:54 PM
IceboxFX's Avatar
yes it did thank you rubber duck. i just want to rebuild them to stock, with the price of fuel i can't see dumping extra fuel just to go faster, eventhough i would like to. i just want to get the truck running right.
__________________
Superchip
Green air intake
4"MBRP w/DP
08 Diff Cover
HPX
CCV
-For Sale-
Truck pics
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
