Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 10:01 PM
lee5563 is starting off with a positive reputation.
Non-running 92 7.3L Where should I start?
I just bought a non-running 92 F350 crewcab with a 7.3L diesel in it. The guy I bought it from bought it non-running and never looked into it. I bought the truck for the dana 60 front axle but would like to use the engine if it will run. Other than owning a 6.0L in my cube van I don't know where to start. I know how they work but have never worked on them. All my knowledge is in ford gas motors. Any help on where to start looking or testing would be great. Engine does turn over. Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-17-2008, 10:41 PM
George D.'s Avatar
George D. is starting off with a positive reputation.
Fule. see if you have fule to the shrader valve on the filer head then see if you have fule to the injector line. Also check for power to the fule cut off solinoid on the top of the injection pump.
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
  #3 (permalink)
Old 05-17-2008, 11:15 PM
PLC7.3 is starting off with a positive reputation.
Try and roll the engine over by hand using the crank bolt.........then.....
Start with 2 good 850CCA batteries........
See if ignition and starter work........"Fast"
Consider replacing the fuel filter........ not required if a good one is installed.....
Make sure the tank selected has at least 1/3 tank of fuel.....
Check oil level.......coolant level.....
report any problems so far........
__________________
93 F250 SC 4x4 E4OD 355LS
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
