Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 09:54 PM
samurai's Avatar
samurai is starting off with a positive reputation.
BF Goodrich Mud Terrains
I have a 2008 F250 FX4 Crew Cab w/6.4 diesel. Getting a set of Nitto Mud Grapplers on Monday except...
BF Goodrich (my brand of choice for 10+ years) makes the same size 35 x 12.5 R18 in the Mud Terrain which is what I am looking for. B UT the BF Goodrich Mud Terrain 35 x 12.5 R18 is only D rated for weight.
I am set to have the Nittos put on Monday morning, BUT I can always change my mind before then. WHAT are your thoughts??
  #2 (permalink)
Old 05-17-2008, 10:04 PM
texastech_diesel's Avatar
texastech_diesel is starting off with a positive reputation.
Meh. If you're looking at 35's you probably aren't towing or hauling a whole lot. The D's will support the truck, but not really anything else. The sidewall flex under a heavy load is what will damage the tires.
__________________
Wreck em Tech - Go Red Raiders
  #3 (permalink)
Old 05-18-2008, 04:35 AM
cartmanea is starting off with a positive reputation.
Take a look at Toyo MTs, BFG KM2s, or Mickey Thompson MTZ Radials. Those are what I'm trying to decide between.
__________________
  #4 (permalink)
Old 05-18-2008, 05:25 AM
nightmove is starting off with a positive reputation.
I put on a set of goodyear silent armor on my 07 F-350 DIESEL load range E . Great in snow and mud. cost me 215 each.
  #5 (permalink)
Old 05-18-2008, 08:09 AM
UP_There's Avatar
Say ello to my Lil friend
UP_There has a very good reputation on FTE.UP_There has a very good reputation on FTE.UP_There has a very good reputation on FTE.UP_There has a very good reputation on FTE.
the D vs. E always seems to come up with BFG's. If you take the stock tires on a Ford which are E rated, and compare them to 315's which are D rated, the D's are rated higher.......LOTS of guys run stock tires and tow to full capacity. I have always ran D range tires, and do tow. Never had any probs whatsoever!
__________________
Travis PAA Member #5.0
2000 F250 4x4 PSD with THE DP-TUNER
"Assorted Goodiez" with LOTS more to come.
"Regular Apes have Superchips in their Banana's, RAPED Apes have DP's in theirs"
Roadside Help Network
PMS Starter kit!
  #6 (permalink)
Old 05-18-2008, 08:19 AM
UP_There's Avatar
To add to this.....here are the specs for BFG A/T's. Stock size 265/75/16E range are rated at 3042@65psi. 315/75/16D range are rated at 3195@50psi. Everybody is always scared of D range tires.....but they never look up the specs!
__________________
PMS Starter kit!
  #7 (permalink)
Old 05-18-2008, 09:36 AM
BillyBob69's Avatar
BillyBob69 is gaining momentum as a positive member of FTE.
Quote:
Ditto...I run D rated BFG All terrains and I regularly pull 14 to 18K loads of hay every month.
__________________
99 F350SD Lariat Crew Cab
7.3L PSD - 4x4
I got a truck for my wife...Good trade huh?!
  #8 (permalink)
Old 05-18-2008, 11:48 AM
I've looked at the specs, a lot.
Toyo AT 315/75/16, D-rated, 3195 lbs (I have this now)
Toyo MT 315/75/16, E-rated, 3860 lbs. (my next tire, unless I get some 18s)
265/75/16E Load Ratings:
Toyo M-55 - 3415 lbs.
BFG AT - 3415 lbs.
UP_There, you got the wrong spec, 3042 lbs is for the D rated 265/75/16 BFG.
__________________
  #9 (permalink)
Old 05-18-2008, 11:57 AM
UP_There's Avatar
I got the numbers right off BFG's page. This is a never ending debate
__________________
PMS Starter kit!
  #10 (permalink)
Old 05-18-2008, 01:47 PM
I'm not doubting you looked at their website, but you still got the numbers switched. They list the E rated first, then the D rated. 265/75/16E is 3415 lbs and 265/75/16D is 3042 lbs. Take a look again if you don't believe me, I just want everyone to have the correct info.
BFGoodrich Tires | All-Terrain T/A® KO | Tire Sizes & Specs
__________________
  #11 (permalink)
Old 05-18-2008, 01:50 PM
DCSpecial's Avatar
FTE Sponsor
DCSpecial has a good reputation on FTE.DCSpecial has a good reputation on FTE.DCSpecial has a good reputation on FTE.
D vs E isn't as important as the actual load rating IMO.
I've seen some E rated tires that have a max load of 2910lbs, which is way to light for a SD.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
