Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 09:41 PM
Whitezmbie is starting off with a positive reputation.
Tachometer acting up?
The tach on my 95 stroke is acting up. When I start the truck it will shoot to 1500 rpm and stay there soemtimes the whole time I drive around. Occasionaly it will drop the the actual rpm and rise and fall as I drive correctly bet them sometimes it will jump right back to around 1500 or 1600 and stay there. Is the tach going bad or fault wireing??? I know it is idleing fine but it bugs me that i cant always see my correct rpms. Thanks
__________________
1995 f-150 4x4
302 w/ fipk
4.56 gears w/ 35 in bfg's
headers and dual exhuast
  #2 (permalink)
Old 05-18-2008, 01:25 PM
Cuda_jim's Avatar
BECOME A ------------>
Cuda_jim has a good reputation on FTE.Cuda_jim has a good reputation on FTE.Cuda_jim has a good reputation on FTE.
Could be the tach or the wiring. Pretty simple gage, It gets it's signal right from the PCM. The PCM get it's info from the CPS. A good scanner will tell if the signal is good coming from the PCM. If the engine is running OK the CPS is not your trouble.
My WAG is a bad tach.
Remove and re-seat the 2 large connectors on the back of the instrument cluster.
The 14 pin black connector is the one you want to look at.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
