Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 10:01 PM
George D.'s Avatar
George D. is starting off with a positive reputation.
Cool Engine locked up.
Well I went and got some soder to fixe some wiring then parked my truck for 3 hours while waiting for it to cool and then fixing the wiring.
when i went to start it the starter engaged tryed to turn then stoped. So I pulled the cover of the torque converter and spun it over by the fly wheel it had no noticeable extra efort but I heard what sounded like fluid trickeling in to the exahust. then tryed to start it.
It started right up and ran fine no smoke. truck doesn't smoke while driving either. So what is going on?
As far as i can figure I might have a injector leaking down. Could this cause this? I have replaced them about 4 months ago with brand new ones, because #1 injector was leaking so bad it put so much fule in my oil that I lost oil presure at idle, and it never did this. If it were cavitation i should have seen water come out the tail pipe plus it should blow white smoke.
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-17-2008, 11:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
Check the oil for both over full and coolant contamination.
There is about 2.5 cu. in. volume left in the cylinder with the piston at TDC in round numbers.
So all it takes to hydrolock the engine is a little over 2 cubic inches of fluid.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #3 (permalink)
Old 05-17-2008, 11:25 PM
George D.'s Avatar
Oils good. could that much fule leak past the pintle of an injector? I just dumbed a botle of diesel clean in since I haven't run any threw the last two tanks.
__________________
  #4 (permalink)
Old 05-18-2008, 12:18 AM
PLC7.3 is gaining momentum as a positive member of FTE.
Had any rain ...........
__________________
93 F250 SC 4x4 E4OD 355LS
  #5 (permalink)
Old 05-18-2008, 12:21 AM
George D.'s Avatar
Nope 113* today with out a cloud in site.
__________________
  #6 (permalink)
Old 05-18-2008, 05:20 PM
George D.'s Avatar
Well it did it again this morning but it started with the starter wich caused the gunk to shoot ou the exaust It did not smell like coolant or fule felt like water and evaporated too fast to be coolant.
The only thing I can think of is one of my new injectors are leaking and the carbon in the exaust is covering the semel. Dose this sound possible? my room mate was a chevy diesel mechanic back when they had the 5.7 and 5.2 and said that thats probly whats going on.
I would like a second opinion befor I write a nasty letter to the company I bought them from.
I replaced all 8 when one was bad because I didn't want to have to deal with this for a while.
__________________
  #7 (permalink)
Old 05-18-2008, 05:52 PM
George D.'s Avatar
oh also when it does this it misses on start up like when you have just had an injector line off. also my return lines have started to leak fairly badly this couldn't cause fule to leak past the pintle could it? The pintle should still seal right?
It runs fine once it runs for a few seconds.
__________________
  #8 (permalink)
Old 05-18-2008, 05:56 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
It sounds like its doing it pretty consistently on cold startup. What I would try is to pull all the glow plugs the next morning and than crank if over. The stuff that is in there should shoot out, and you can dentify what the fluid is and the cylinder that is doing this.
If it is indeed fuel, than I'd say it would be time to write that letter at that point.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #9 (permalink)
Old 05-18-2008, 05:59 PM
George D.'s Avatar
Yeah don't realy have time to do that since i have to work tomarow pluss with my luck I would bust a tip off in there then i would realy be screwed.
__________________
  #10 (permalink)
Old 05-18-2008, 06:06 PM
David85's Avatar
Dang, sounds like lousy timing for this to happen now. At the very least, I would turn it over by hand before attempting to start it cold in the morning to prevent any potential damage.
When you do have the time, you could pop the injectors out instead. Even just loosening them a bit should provide a path of escape for the fluid. Do what you can, but don't put it off for too long if you are still running it.
__________________
  #11 (permalink)
Old 05-18-2008, 11:36 PM
George D.'s Avatar
Well this afternoon I had to drive it to the store didn't think about it started fine and didn't shoot anythink out and it had been sitting as long as it had been the first time.
Maybe there was just some crud in the pintle that the diesel clean got out. will se in the morning since whan i turn it over by hand I can hear it tricling into the crossover.
__________________
  #12 (permalink)
Old 05-18-2008, 11:51 PM
The return lines should not be putting diesel into the cylinder.
And I would have a hard time believing you could get enough fuel to leak out of an injector to actually hydrolock the engine.
I could see leaking out enough fuel that the compression ratio would be very high in that cylinder though, which would make it a lot harder to compress that cylinder.
You are probably hearing it trickle into the oil pan, the exhaust valve should be closed on the compression stroke.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #13 (permalink)
Old 05-19-2008, 01:24 AM
George D.'s Avatar
yeah it probly isn't hydrolocked but the starter couldn't crank it the first time it hapend and the second time it pussed it out the exaust made a awful mess.
If it were coolant i would be getting white smoke so the only thing it could be is fule, right? I could definately tell it was not oil.
__________________
  #14 (permalink)
Old 05-19-2008, 01:02 PM
LilDuke's Avatar
He rides the short bus.
LilDuke is starting off with a positive reputation.
Just a note, the exact same thing was happening to me. Turned out the pos wire on the starter coming from the batt was loose.
I'd check both engine grounds, and batt wires for loose/corroded connections first.
__________________
Dave
'93 Ranger XLT 4.0, 4x4, 179,000 and counting. (For Sale)
'92 F-150 XL I6, M5OD, 4x4, 186,000 and counting. (For Sale)
'90 F-250 XLT 7.3 IDI, E4OD, 181,000 and counting.
'95 Explorer XLT 4L, 4R55E, 4x4. 156,000
Hiding in my own little corner of the world!
  #15 (permalink)
Old 05-20-2008, 01:27 AM
George D.'s Avatar
That wouldn't cause stuff to spew out the exaust though.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
