Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 08:52 PM
ozzy460's Avatar
ozzy460 is gaining momentum as a positive member of FTE.
did i hurt my truck?
i'm writing cause i'm retarded and stupid. and stubborn. went n a 200 mile trip today to pick up a truck i bought. got within 60 miles from home and herd a noise it was the vaccume pump. decided to see if i could make it cause no parts stores had one. wel got within 5 miles from home, pump sized, threw the belt, got hot, waited til it cooled drove till it got hot again, blew the radiator that time, waited till it got cool and ran it home, got hot again, till starts fine, not milky oil ,think i will have issues? head gasket,
__________________
ozzy460
94.5 powerstroke 5 speed f250 4x4 d60 swap
77 f250 highboy 4x4 4 in lift 38's
74 f250 highboy dually with 38 in duals
70 bronco 4 in lift 39s
57 f250 rat rod
93 ranger 10in lift 35 in iroks straight axle 44 9in lockers front and rear
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-17-2008, 10:07 PM
Todd525's Avatar
Todd525 is starting off with a positive reputation.
heat is number one issue with a motor. Good luck, I think your going to need it in the long run. My answer would be a definite yes. it never helps to run it hot, and you should never even try to limp without coolant. I am going to be nice on this, that wasnt very smart.
__________________
96 F350 CC Dually PSD. Tuner, straight pipe, 6637 filter, ribbed diff cover, 12.7k mod, 28k tranny cooler, 3 plate TC, autometer boost, trans, and pyro. Used 4 Car Haulers, 5th wheels, goosenecks, Fat Chicks.
01 F250 CC 4x4 PSD. SOLD.....Kinda missed already, and its Day 1.
  #3 (permalink)
Old 05-18-2008, 02:53 AM
RubberDuck's Avatar
Death Row Inmate #1
RubberDuck has a good reputation on FTE.RubberDuck has a good reputation on FTE.RubberDuck has a good reputation on FTE.
Man, I really don't think that was a good idea ozzy. I would put it back together, pray on your hands and knee's to the powerstroke gods, and hope for the best. But if it were me, I would be looking for a spare motor on craigslist. Just my .02
__________________
RubberDuck
1995 F350 Crew Cab 4x4 dually
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
DP Tuner 2 pos. w/ custom switch
Hot Pedal
Gear Vendors OD
Good bye No.3 I'll miss you.
RIP #17
  #4 (permalink)
Old 05-18-2008, 03:17 AM
maverick1701 is starting off with a positive reputation.
You need to sacrifice a cummins to the powerstroke gods and beg for forgiveness
__________________
1996 F-350 Crew-Cab LWB w/7.3;201K miles;33in toyos;6in lift;E4OD;Warn Hubs;Replacement bumpers
1994.5 F-350 Crew Cab LWB W/7.3 Powerstroke;317,000 miles;410s;33in BFG Mud-Terrain 305/70-R16;5-spd;Warn hubs;115gal transfer tank;grill guard;no cats;no muffler;Trail-Boss "Roper Rack"
http://youtube.com/watch?v=BRzhJdmGYNY
  #5 (permalink)
Old 05-18-2008, 07:06 AM
WALJON is gaining momentum as a positive member of FTE.
Wow I wish you luck I did this once a long time ago with a 351M spun the bearings and ended up with a bad bottom end knock
__________________
96 F250 cab & 1/2 4x4 powerstroke
3" down pipe straight exhaust
6637 Intake mod,ccv mod
FPR shim 70 PSI
Glow plugs on a switch
Firestone air rite suspension
203 stat
  #6 (permalink)
Old 05-19-2008, 06:48 PM
ozzy460's Avatar
well guys. tell me what to look for. trucks together and running, no milk in the oil, no bubbles in the rad. no wierd sound and still has good oil pressure.
__________________
ozzy460
57 f250 rat rod
  #7 (permalink)
Old 05-19-2008, 06:52 PM
Todd525's Avatar
since you cant see the bearings, you cant look for them until you do a teardown. You cant see the headgasket you cooked, you ant see the wire harnesses you baked, so your right, if you stand there with the hood up, you wont see anything. The damage lurks Under everything you CAN see... Hopefully with ANY luck you wont have to find out how much of a pain it is to pull this motor out and do a rebuild.
__________________
  #8 (permalink)
Old 05-19-2008, 07:07 PM
tjbeggs's Avatar
Fisher of Men
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
Its never good to over heat but since you don't see any milky oil and no other issues now you should be fine. Just keep an eye on the oil and coolant for the next two weeks.
__________________
Tim
Proud User of "The Cure"
For sale- 95 accelerator pedal, Gray interior and dash part, cab and more PM your request!
Click the Picture for wiring diagrams, tech info and Pictures!
  #9 (permalink)
Old 05-19-2008, 07:17 PM
Action4478 is gaining momentum as a positive member of FTE.Action4478 is gaining momentum as a positive member of FTE.
Quote:
I have to agree with TJ ..All the gloom & doom is unnessary unless you are having symtoms of a problem..These things aren't made out of marshmellows...Unless you ran it out of oil too, don't be concerned about the bottom end ,a head gasket problem will show itself right away ...Relax ,,, and keep an eye on things ....
__________________
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
www.fordtransmissioncure.com
Special thanks to RacerX www.racerxautomotive.com
  #10 (permalink)
Old 05-19-2008, 08:08 PM
Quote:
Good to hear so you had it up to normal temps and it seemed fine?
__________________
FPR shim 70 PSI
203 stat
  #11 (permalink)
Old 05-23-2008, 09:48 PM
ozzy460's Avatar
well all is good i have no issues. but guess i learned somethin, stop when its hot, heres what i had t replace( thak god not the motor) 3 idler pullys, belt tensioner, vacuume pump, serp belt( twice) idn't know the belt tensioner was bad and shredded the new one), and new radiator,( blew the lower cores right out) anyone got a rad for sale? anywayal is goo, thanks for the kind words and prayers
__________________
ozzy460
57 f250 rat rod
  #12 (permalink)
Old 05-23-2008, 09:50 PM
c00nhunterjoe's Avatar
c00nhunterjoe has a good reputation on FTE.c00nhunterjoe has a good reputation on FTE.
Change The Oil!!!!!!!!!
__________________
97 F-250, 4.10's Auto, Superchip, All mods by c00nhunterjoe's performance shop http://community.webshots.com/user/c00nhunterjoe
http://youtube.com/c00nhunterjoe
  #13 (permalink)
Old 05-23-2008, 09:51 PM
ozzy460's Avatar
oh and took your advice, took a 90 cummins dodge to the crusher yesterday, maybe thats what helped
__________________
ozzy460
57 f250 rat rod
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
