i'm writing cause i'm retarded and stupid. and stubborn. went n a 200 mile trip today to pick up a truck i bought. got within 60 miles from home and herd a noise it was the vaccume pump. decided to see if i could make it cause no parts stores had one. wel got within 5 miles from home, pump sized, threw the belt, got hot, waited til it cooled drove till it got hot again, blew the radiator that time, waited till it got cool and ran it home, got hot again, till starts fine, not milky oil ,think i will have issues? head gasket,
__________________
ozzy460
94.5 powerstroke 5 speed f250 4x4 d60 swap
77 f250 highboy 4x4 4 in lift 38's
74 f250 highboy dually with 38 in duals
70 bronco 4 in lift 39s
57 f250 rat rod
93 ranger 10in lift 35 in iroks straight axle 44 9in lockers front and rear
heat is number one issue with a motor. Good luck, I think your going to need it in the long run. My answer would be a definite yes. it never helps to run it hot, and you should never even try to limp without coolant. I am going to be nice on this, that wasnt very smart.
__________________
96 F350 CC Dually PSD. Tuner, straight pipe, 6637 filter, ribbed diff cover, 12.7k mod, 28k tranny cooler, 3 plate TC, autometer boost, trans, and pyro. Used 4 Car Haulers, 5th wheels, goosenecks, Fat Chicks.
01 F250 CC 4x4 PSD. SOLD.....Kinda missed already, and its Day 1.
Man, I really don't think that was a good idea ozzy. I would put it back together, pray on your hands and knee's to the powerstroke gods, and hope for the best. But if it were me, I would be looking for a spare motor on craigslist. Just my .02
__________________
RubberDuck
1995 F350 Crew Cab 4x4 dually
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
DP Tuner 2 pos. w/ custom switch
Hot Pedal
Gear Vendors OD
Good bye No.3 I'll miss you.
well guys. tell me what to look for. trucks together and running, no milk in the oil, no bubbles in the rad. no wierd sound and still has good oil pressure.
__________________
ozzy460
57 f250 rat rod
since you cant see the bearings, you cant look for them until you do a teardown. You cant see the headgasket you cooked, you ant see the wire harnesses you baked, so your right, if you stand there with the hood up, you wont see anything. The damage lurks Under everything you CAN see... Hopefully with ANY luck you wont have to find out how much of a pain it is to pull this motor out and do a rebuild.
__________________
Its never good to over heat but since you don't see any milky oil and no other issues now you should be fine. Just keep an eye on the oil and coolant for the next two weeks.
__________________ Tim Proud User of "The Cure" For sale- 95 accelerator pedal, Gray interior and dash part, cab and more PM your request!
Click the Picture for wiring diagrams, tech info and Pictures!
I have to agree with TJ ..All the gloom & doom is unnessary unless you are having symtoms of a problem..These things aren't made out of marshmellows...Unless you ran it out of oil too, don't be concerned about the bottom end ,a head gasket problem will show itself right away ...Relax ,,, and keep an eye on things ....
__________________
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Good to hear so you had it up to normal temps and it seemed fine?
__________________
96 F250 cab & 1/2 4x4 powerstroke
3" down pipe straight exhaust
6637 Intake mod,ccv mod
FPR shim 70 PSI thanks ROG
Glow plugs on a switch
Firestone air rite suspension
203 stat
well all is good i have no issues. but guess i learned somethin, stop when its hot, heres what i had t replace( thak god not the motor) 3 idler pullys, belt tensioner, vacuume pump, serp belt( twice) idn't know the belt tensioner was bad and shredded the new one), and new radiator,( blew the lower cores right out) anyone got a rad for sale? anywayal is goo, thanks for the kind words and prayers
__________________
ozzy460
57 f250 rat rod
