05-17-2008, 05:11 PM
These engines with a clean cooling system are hard to get any temp in at idle, takes a good load or highway run to get up to temp normally. If you are seeing 200 at the top hose, you are alright. Mine only ever gets up to the N in normal at the hotest I've ever seen it. Stock guages are not know to be accurate, but they should be consistent at whatever yours reads at.
__________________
Kevin L.
93 F350 7.3 IDI 4x4, E40D with Multi Disc TC, Ram air, Stans Headers, 3" to Y- 4" exhaust,3.55, B&M shift plus, Pyro, Fuel opened 1-1/2 flats- Happy with power increase!
48 F-68 Stock- in restoration
