Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 04:52 PM
the grimlin is starting off with a positive reputation.
Truck not overheating or heating up?
Well My father and I put him together a truck from parts. He didn't want to spend much so we re-used everything we could even a used water pump (that was removed from a overhauled motor that sat for several years) and thermostat. He tested the T-stat in hot water with a ray-tech gun and it opened at around the 190's.
The problem were having is the temp gauge does not come up. we have tested the gauge by grounding it worked fine installed several sensors even a brand new one. $43.00 wow did he squeak. the temp at the top hose is around 200 and the same with the coolant with the cap off. But the lower hose is cold but yet today it's 90 out and the truck does not over heat. I hear the fan all the time when I free rev the motor. Can the fan clutch be bad cooling the ingoing water to the motor down that much that it wouldn't heat up the motor?
Thanks starr
  #2 (permalink)
Old 05-17-2008, 05:11 PM
KJLYPW's Avatar
KJLYPW is starting off with a positive reputation.
These engines with a clean cooling system are hard to get any temp in at idle, takes a good load or highway run to get up to temp normally. If you are seeing 200 at the top hose, you are alright. Mine only ever gets up to the N in normal at the hotest I've ever seen it. Stock guages are not know to be accurate, but they should be consistent at whatever yours reads at.
__________________
Kevin L.
93 F350 7.3 IDI 4x4, E40D with Multi Disc TC, Ram air, Stans Headers, 3" to Y- 4" exhaust,3.55, B&M shift plus, Pyro, Fuel opened 1-1/2 flats- Happy with power increase!
48 F-68 Stock- in restoration
  #3 (permalink)
Old 05-17-2008, 08:08 PM
It reads nothing it don't move at all. I started mine today just after I made the first posting drove it about 4 miles and it was up to it's normal spot very low on the left side of normal. I got home and unhooked the same wire that I thought was to the gauge on mine it did nothing my gauge stayed working. but the same wire on my fathers seem to run the gauge. (left front head temp sensor) if I unhook the one right by it in the block my gauge stops working. He is on his way over now I will get to the bottom of this tonight I hope.
Starr
  #4 (permalink)
Old 05-17-2008, 08:10 PM
I forgot to say my fathers is a 90 and mine is a 94 but I don't think this should matter.
Starr
  #5 (permalink)
Old 05-17-2008, 09:47 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
www.ford-trucks.com/guidelines.html
FTE Moderator in the IDI diesel forum.
WV Chapter Member
  #6 (permalink)
Old 05-18-2008, 12:06 PM
I never got to it last night but the time I worked on it before if I grounded the temp light switch it would make the gauge go up. hum maybe I have it wired wrong I will have to check that today.
thanks for the pic Starr
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
