Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 04:35 PM
oddrod is starting off with a positive reputation.
Thumbs down E85
hello all.
can anybody tell me if I can run E85 in my 85 F-250 7.3
  #2 (permalink)
Old 05-17-2008, 04:41 PM
rmalottwtes30's Avatar
rmalottwtes30 is starting off with a positive reputation.
E85 is a gasoline......Wont run in your diesel....You can run biodiesel...
__________________
Ryan
1985 F-250
6.9 Diesel
Hypermax 3.5 exhaust
Injector Pump turned 1 flat
Homemade ram air intake
http://s32.photobucket.com/albums/d5...Ford%20Diesel/
  #3 (permalink)
Old 05-17-2008, 04:58 PM
ok do I need to make any modifications to run biodiesel
  #4 (permalink)
Old 05-17-2008, 06:06 PM
Running Bio you really only need to replace all the seals as bio diesel will eat the seals away if there not new....I dont know why you would want to run bio though because the last time I checked biodiesel is around the same prices as regular Diesel
__________________
Ryan
1985 F-250
6.9 Diesel
  #5 (permalink)
Old 05-17-2008, 10:53 PM
George D.'s Avatar
George D. is starting off with a positive reputation.
Quote:
And besides it hurts every one more if you run the bio from gass staions as its ingreadiants are farmed instead of food, wich drives up the cost of food.
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
  #6 (permalink)
Old 05-17-2008, 11:10 PM
last time I looked there was almost a buck a gallon differance here
  #7 (permalink)
Old 05-17-2008, 11:27 PM
fellro86's Avatar
Iowa Chapter lead
fellro86 has a very good reputation on FTE.fellro86 has a very good reputation on FTE.fellro86 has a very good reputation on FTE.fellro86 has a very good reputation on FTE.
Quote:
Biodiesel can be made from many things, much of it is waste otherwise, so before you go running it down, you may want to do some homework. Not all biodiesel is made from fresh vegetable oil, much of it is from waste cooking oil, animal fats, and other places. If you want a place to put blame for higher food costs, try higher fuel and energy costs, higher fertilizer costs, as well as higher seed costs.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, A518 auto (for now)with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
  #8 (permalink)
Old 05-18-2008, 05:21 PM
rockcrawlerdude is starting off with a positive reputation.
Quote:
dang thats crazy! bio is slightly more than diesel here in central texas...
__________________
1989 F350 Crew Cab 4x4 LONG Bed 7.3 IDI Diesel with 4.10's and a EOD Tranny!
  #9 (permalink)
Old 05-18-2008, 05:35 PM
FORD MEGA CAB!!! is starting off with a positive reputation.
Doesn't bio have less energy than regual diesel therefore you would get less miles per gallen which would level out up to the cost of regular diesel? Just curious.
  #10 (permalink)
Old 05-18-2008, 05:46 PM
Lead Head is gaining momentum as a positive member of FTE.
The energy difference between regular diesel and bio diesel is not enough to make bio not worth it. Unless of course you are paying the exact same price for both, then bio would not be worth it
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #11 (permalink)
Old 05-19-2008, 09:50 PM
dakotajeep is starting off with a positive reputation.
The misleading thing about BioD is that there are all sorts of blends ranging from 2% to 100%.
A small amount of BioD is actually good for our old IDI's since the ULSD doesnt lubricate like our IDI's need......
my .02
__________________
1994 F350 Crew Cab 7.3 IDI NA SRW 3.55 Dana 60 and 10.25 Sterling 285/75 16's Dayton Timberline
Synthetics in the diffs and transfer case
In its former life it worked for the US GOVT
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
