have a 1997 F250 w/tilt strg. no air bags. Need picture diagram of re-installation of upper brg. and spring. I am unable to get to a dealer for diagram at this time. I have removed all worn parts which were very worn or broken. I would appreciate any help with this matter
Install steering column bearing tolerance ring and steering column bearing sleeve over steering shaft to upper steering column bearing. Pict 1
Install steering column upper bearing spring and new bearing retainer on top side of bearing spring using a 3/4-inch I.D. by 2-1/2-inch long PVC pipe Pict 2
Install turn indicator cancel cam, flush surface up. No pict
Jim, Thank you very much! I just got home from out of town and found your message. It is very helpful, look forward to future questions or help that I may be of assistance.
Again, Thank you!
Ruben
