2004 F150 Cruise control problems - Ford Truck Enthusiasts Forums
Old 05-17-2008, 04:30 PM
Hpsandguard Hpsandguard is offline
Hpsandguard is starting off with a positive reputation.
Hey everyone,
Wanted to know if anyone was having the same problem. My Cruise control started acting up, first it would shut off after about 20 minutes, then 5, now it will not turn on at all. It doesn't sound like something as simple as a fuse. Ant help here would be appreciated. Thanks
Truck is 04 F150, 5.4 with automatic.
Old 05-18-2008, 08:31 PM
rumbler2004 rumbler2004 is offline
rumbler2004 is starting off with a positive reputation.
cruise control problem on 2004 F-150 FX4
Iam having the same problem . Lately the cruise control would work intermediately then went out all togetheer. i took it to th Ford Dealer they haven't heard about any issues on this matter. is anyone else having this problem?
Old 05-19-2008, 09:31 AM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
Sounds like there's a bad connector someplace. On my 04, I have not had a single issue with the cruise. Sorry can't be more helpful
Old 05-19-2008, 01:46 PM
VFR_Man's Avatar
VFR_Man VFR_Man is offline
VFR_Man is starting off with a positive reputation.
Could it be something as simple as the brake light switch acting up, turning the cruise off even though the brake pedal is not depressed?
Old 05-19-2008, 02:22 PM
NDNMOJOMAN NDNMOJOMAN is offline
NDNMOJOMAN is starting off with a positive reputation.
My cruise has shut off on me also. It has only happened a couple of times but not within the last month or so.
Old 05-19-2008, 09:31 PM
timanator1 timanator1 is offline
timanator1 is starting off with a positive reputation.
Recall Notice
I havent had any problems with the cruise control but I did receive a notice for a recall that involves the cruise controll unit. Seems that after you park your truck the cruise control unit overheats and could possibly catch fire. Dont know if the problems are related, but you might want to take it to your local dealor.
Old 05-19-2008, 09:49 PM
Joel_P_Jr's Avatar
Joel_P_Jr Joel_P_Jr is offline
Joel_P_Jr is starting off with a positive reputation.
When i first got my truck ('03) the cruise control didn't work. My dad runs the ford dealership in Slidell and he took it to work and they fixed i right away. i can ask him about it if you want?
Old 05-25-2008, 10:55 PM
Problem is fixed(I Hope)
Well, after chasing fuses, conectors and leads. I broke down and took "Red" (My 04 Lariat) into the dealer and had them look at it. Honestly, they were stumped. After two hours, they came to the determination, it was a faulty brake peddle relay switch. So any of you who are having a common or similar problem, check that. Will keep y'all updated.
Old 06-08-2008, 10:57 AM
plankstang plankstang is offline
plankstang is starting off with a positive reputation.
I am currently having this problem with my truck and was wondering if you could tell me where this brake pedal relay switch is located, my truck also does not require the brake pedal to be depressed in order to switch from park. Im not sure if that problem would be related but it sounds like it would be.
Old 06-08-2008, 04:34 PM
I am not exactly sure where its located, I can assume and I hate to do that. I was thinking it was something like a traditional brake light relay, but with these trucks, could be located else where.
Old 06-11-2008, 12:06 PM
crusie control problems still
Hey ai ve been trying to figure out why my cruise control still flikkers on while going down the road. I tried to turn it on at 40 mph and it worked for a while. Then aI got up to 55 mph I did not touch the brake pedal Then it would flicker off. I don't think it could be a brake pedal realy since I did not touch the brakes. Any more suggestions. The dealer is stumped. Oh yeah they want me bring it in , Then it would proably work fine. Any body know what years the recall would be on this cruise control ?
Old 06-11-2008, 03:30 PM
The relay that was replaced was sending a false signal to the pcm. The tech that worked the problem was stumped as well, he had tried everything and everything appeared to be working except the cruise wouldn't engage. Since the relay was telling the pcm that the brake was applied, then it wouldn't allow the cruise to be engaged. Hope that makes sence.
Old 06-11-2008, 03:53 PM
Can you tell me where the relay for the pcm is located? Do I need to buy a book? Is it hard to reolace? I am a do iselfer.
Thanks
Old 06-12-2008, 11:27 AM
The PCM is located on the passengerside firewall. I honestly don't know where the switch is physically located. IF you had a book or a diagram that showed you the layout of the system, you could probably trace out where it is located and at least check it out to see if that is your problem. I was told that it is a redundant system so it could be that relay or the other relay for the brake lights. Hope I helped a little.
HP
1992 f150 5.0 cruise control problem bishopgeer 1987 - 1996 F150 & Larger F-Series Trucks 2 12-19-2014 11:00 AM
1994 F150 Horn & Cruise Control problem Jtarr 1987 - 1996 F150 & Larger F-Series Trucks 16 12-01-2014 05:25 PM
cruise control ramhunter5877 2004 - 2008 F150 4 10-12-2014 09:10 PM
Climate control, Cruise control and backup lamps fuse keeps blowing bfaulkner 1997 - 2003 F150 7 01-17-2011 12:39 PM
2006 F150 Cruise Control Problem Engineer2 2004 - 2008 F150 3 12-30-2008 05:54 PM
Tags
2004, brake, control, cruise, doesn, f150, ford, fx4, module, pedal, problem, relay, switch, turns, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
