I have a y-block of unknown origin. It is not original to my truck. The numbers on the block are ECT 6015 B. It has a 4bbl intake, tach drive distributor, and rams horn exhaust manifolds. The head numbers are 5750117, and the exhaust manifolds are ECS9430A. I would like to know where to look for info on this engine, if anyone knows. Also, I would like to reuse the trans that's behind this engine on a 460. The trans is a 5 speed with a PTO. The numbers on the trans are E-LC-KO with 207794 below. Is there a bellhousing or a scattershield that would accept this trans? This combo is in a 1954 F800. Any ideas? I am new to old Foed trucks and any help is appreciated.
__________________
Tim M.
'03 F350 CC Lariat 4X4 PSD
'06 F150 Supercrew 4X4 5.4
'54 F800 Big Job
'64 F100 short and wide
'96 GMC Topkick, '89 International 9670
Did you find out what size motor you have. I might be interested in the exhaust manifolds if it is a Y-Block. If all the exhaust manifold bolts are in a straight line it is most likey a Y-Block probably a 272 or 292. If the exhaust manifold bolts are staggered then it may be a HD motor 302 or 332 I think. There are some other people on this forum who know more about this than I.
Thanks Charles
__________________
Restoring at the speed of a slow sick snail !
I haven't received any other responses yet. The first and the last bolt holes are not in line with the other 4 on the exhaust manifolds. I am an FE/385 person. These older engines are strange to me.
__________________
Tim M.
'54 F800 Big Job
hi my books said your y block is a 332 hd
hello, this is a lincoln and big truck y-block, used in lincolns 52-57 and big trucks 52-64. very few parts interchange with a ford y-block. this trans should bolt to a 460 truck standard bell. hope this helps, wayne.
