Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 02:31 PM
danocross is starting off with a positive reputation.
Tonneau covers: do they increase fuel economy?
I have noticed more bed cover advertising on here lately. In the past I was always hot to buy a bed cover, but in the end it seemed too inconvenient to not have full access all the time.
Anybody have a bed cover who can pass along verified fuel savings? I have seen them priced from around $500 up to a couple of thousand, so that has to be factored in. I guess in the end, you get one for securing the bed and the contents therein, fuel economy might be a side benefit.
  #2 (permalink)
Old 05-17-2008, 06:57 PM
sandmanf250 is starting off with a positive reputation.
covered bed
tests have been done on this subject and it seems no cover and tailgate up was the best.
  #3 (permalink)
Old 05-17-2008, 08:52 PM
tex25025's Avatar
tex25025 is gaining momentum as a positive member of FTE.tex25025 is gaining momentum as a positive member of FTE.
I actually haven't had any loss or gain on mine, but I am now able to use the bed of the truck for luggage and such when on a trip and have more room for stuff up in the cab then before. Since there is no down side for me to having it up(and plus since it's retractable I can move it back) I keep it out unless I'm hauling alot of barn stuff in the bed or hauling with one of my gooseneck trailers.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #4 (permalink)
Old 05-17-2008, 09:34 PM
thedaddycat is gaining momentum as a positive member of FTE.
I read an article a while back that reported on wind tunnel testing and bed covers. IIRC the results showed a slight gain, maybe on the order of 2-3%. I just ordered an Extang RT tool box cover(fits behind a cross over tool box) and tail gate seal. I had been thinking about it for a while, trying to decide on a full bed cover or mount the box and get the tool box cover. I usually run empty but decided to go ahead and mount the box and get the short cover. We'll see how it goes, it was under $400 for the cover and seal. If I see a 2% gain I will have a ROI of about 3-4 years at today's fuel prices.
__________________
'03 F-350 XLT 6.0 PSD SRW SC SB FX4
Dieselsite coolant & tranny filters, Bright Box, C-BETRs
22" wipers, M-H FD RD Tranny covers, Fluidamper, leveling kit
Power Elbow, Blisteins, gages, MBRP 4" C-back
XCal2 by SDT, HFCM drain, Centrimatic balancers
ESP luber, Oilguard bypass filter on deck
  #5 (permalink)
Old 05-17-2008, 09:55 PM
tex25025's Avatar
Quote:
It'll start taking you less time to see ROI by the end of the year.
__________________
Fluidampner
Headstuds
FASS 150/180
  #6 (permalink)
Old 05-17-2008, 11:50 PM
Pocket's Avatar
Pocket has a good reputation on FTE.Pocket has a good reputation on FTE.Pocket has a good reputation on FTE.
Quote:
Actually yes tests have been done, but you're misquoting the results a tad.
Each brand of truck is different, and even different cab configurations or bed lengths will change the affect. However, it's pretty consistant that just about every truck reduces drag WITH a bed cover.
There's a windtunnel test floating around about a Dodge truck and testing different configurations. Tailgate up, tailgate down, topper, tonneau, cargo net, etc. I believe the tonneau cover reduced drag by a little over 11% in the wind tunnel
Now one thing I did remember about the article is they "guesstimated" fuel economy savings based on the reduced drag. This would be in my mind incorrect, since the physics change when you drive more than 40 mph. However, any reduction in drag does translate into at least some minimal mileage gains.
For most trucks, and typically with Superduties, expect up to a .5 mpg increase in mileage on the highway only with a tonneau cover. Don't expect any gains around town. The .5 mpg improvements is usually a best case scenario.
__________________
Curtis
2002 F-250 PSD
Best time: 15.44 @ 86.48 MPH at 6000ft running stock injectors, no drugs, and 36" tires!!!!
Truck Pics and MODS!!!!
  #7 (permalink)
Old 05-18-2008, 03:40 PM
Quote:
That fits pretty well with what I was talking about. Using a base figure of 18 MPG, a .5 MPG gain is roughly 2.8%. With a base of 16 it is 3.1% and a base of 20 yields 2.5%.
__________________
  #8 (permalink)
Old 05-18-2008, 04:27 PM
diverseth's Avatar
diverseth is starting off with a positive reputation.
I have the Leer hard cover and although I love it I don't think it has helped much with the MPG. Maybe 1\2 at best.
__________________
2006 F250 6.0 FX4 Lariat, CC/SB, Dk Stone,275/65/20 Wheels,Quad Ballast HID Headlights, Python alarm w\remote start &Turbo timer, Eclipse 6600 DVD Navigation w\TV Tuner,10"rear Monitor and back-up camera,JLAudio Amps,Kicker 12"Sub, Leer cap,30,000+ miles on 5w40 Rotella. SCT X3 from Spartan.
  #9 (permalink)
Old 05-18-2008, 10:40 PM
JROSCO6 is starting off with a positive reputation.
We havent seen any gains on either truck my wifes F150 or my 350.
__________________
06 CC SB 4x4 Auto, Acufab power Elbow, Isspro guages,MBRP 4" catback, 2"leveling kit, LineX
  #10 (permalink)
Old 05-19-2008, 08:31 AM
Lonewolftx's Avatar
Road Runnin' Copper W
Lonewolftx is starting off with a positive reputation.
Arrow
There are a couple of threads on this. The MythBusters did a secment on this and found it to be a bust. Try the Discovery website for those numbers.
__________________
BtLW . . .
We're not here for a LONG TIME, We're here for a GOOD TIME! HOOH!
'06 F250 PSD CC SB LKR Fx4 20" Whls Dk Copper
  #11 (permalink)
Old 05-19-2008, 11:09 AM
JJPMach1 is starting off with a positive reputation.
they did it on Mythbusters with a f150.
The cover did do the best, but like stated before, the result was insignificant. 2nd best was leaving the tailgate up, the worst was putting the tailgate down.
I bought a cover just to keep the junk in the bed dry when it rains. But I can't be for sure, but, I think the wind noise inside the cab went down when I put on the bed cover.
__________________
2007 F250 XLT Crew Cab 4X4 Powerstroke - No Mods
2003 Mustang Mach 1, many bolt on mods & 4.10's
  #12 (permalink)
Old 05-19-2008, 01:28 PM
Lonewolftx's Avatar
Wink
I like it as it keeps things locked up, out of sight and dry. Mine is a high grade, Truxcedo lo-profile, canvas model and is easy to roll up when bed is in use and sealed up the rest of the time. Pic's in galery.
__________________
BtLW . . .
  #13 (permalink)
Old 05-19-2008, 02:29 PM
smlford is starting off with a positive reputation.
I got a roll up hard cover and the best gain I've seen is .3 to .5 MPG in a highway situation. No gains around town but like others have said there are other benefits as well.
  #14 (permalink)
Old 05-19-2008, 10:03 PM
Well, I got mine today so I'll probably be mounting the tool box and cover this weekend. It may take a couple of weeks to get even preliminary data(I'll be riding my Harley to work a lot more) but I'll post back once I have anything to report, either of a gain or no gain.
__________________
  #15 (permalink)
Old 05-19-2008, 10:19 PM
Pocket's Avatar
Quote:
Unless they came out with a new episode, the fuel mileage test they did with the F-150 only compared the tailgate up vs down. They didn't do mileage testing with a tonneau cover.
__________________
Curtis
2002 F-250 PSD
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
