Changing the cam
How I did mine:
Remove rocker shafts and push rods,
Remove the distributor,
Turn the engine upsidedown,
Roll the crank through two revolutions,
Make sure the lifters are out of the way,
Pull the timing set, *DON'T* move the crank
at this point, and don't remove the gears
from the chain.
Install your new cam, and using the timing
set, put the cam in the correct position
for the timing set re-install...
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6 (Mods)
'01 ZX2 (No Mods yet)
__________________
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'74 Capri 2L
