Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 12:32 PM
86stepsideF150 is starting off with a positive reputation.
Headlights go out and come back on
As I'm driving, or even just idling with my lights on, I notice one of my headlights will go out, and then come back on a few minutes later. Both of the lights have done it. They'll go out, and then come back on a little later. Usually it's one at a time, but last night I was driving and I had my high beams on, because then both lights will typically be on. As I was driving, I noticed my "HIGH BEAM" display light on the dash went out. I hit my high beam foot switch a couple times, and I couldn't get them to come back on. Then, I realized neither of my headlights were on. I stopped, turned the truck off, waited, turned it back on, and then both lights worked fine. How do I fix this?
  #2 (permalink)
Old 05-17-2008, 02:02 PM
Lazy K is starting off with a positive reputation.
Sounds like a bad ground somewhere.
  #3 (permalink)
Old 05-17-2008, 03:32 PM
Gary B is starting off with a positive reputation.
replace the headlight switch, it has a circuit breaker in it.
  #4 (permalink)
Old 05-17-2008, 06:28 PM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
Yes, it wouldn't hurt to replace the Headlamp switch. The circut breaker in the switch deteriorates with age. Very comon problem.
However, the circut breaker will make BOTH lights go out simutaniously, not one at a time, like you mentioned, so there may be another problem under the hood, triggering the circut breaker. Check the wiring going to the headlamps, under the hood for cuts, abbrations, shorts, etc.... It could also be a faulty headlamp itself.
It's also good practice to replace the dimmer switch at the same time as the headlamp switch.
Use Factory Ford parts for best, and longest performance.
I do believe you have a problem triggering the headlamp circut breaker, rather than the breaker itself being at fault on this occation.
good luck.
  #5 (permalink)
Old 05-18-2008, 02:40 AM
srercrcr is starting off with a positive reputation.
I experienced the same thing years ago....it eventually resolved itself on its own.
__________________
Steve Robbins
'83 XLT Super Cab Long Bed 300-6 (20 mpg hwy) 4OD 3.08, one-owner ordered from the Factory in May '83 with a page-full of options, 175000 miles, all stainless exhaust. Take a look.....
http://s45.photobucket.com/albums/f88/srercrcr/Ford%20F150/?action=view&current=FordF15083.jpg
  #6 (permalink)
Old 05-18-2008, 07:50 AM
Bern_F150_4x4 is starting off with a positive reputation.
Replace the switch; I'd hit the junk yard and pick up a few. The other thing to look at is the alternator's output voltage. Make sure it's 14.7V +- under load. Ohms law states that E=IR, which means that as the voltage (E) drops (low alternator voltage output at idle), the current (I, amps) thru the headlight switch will have to increase to maintain the wattage output at the load (R, headlamps) which could cause a weak headlight switch breaker to open.
A strong battery and alternator will provide consistant bright lights and lower current flow thru the entire vehicle electrical system. Increasing the idle speed a couple hundred RPM on my '85 was all it took to remedy the dim lights and slow wipers at idle. Good luck
__________________
'85 F150 4x4 300CID, NP435, 3.08's, Factory 15x8's, 31" Goodyears, Lock-Right in the back.
'86 F250 Supercab 4x4HD, 460 4V, T19, D50/Sterling 10.25 Trac-lok, 3.55's
FTE, yet another reason to have a networked PC in the garage!
The other side of green...
  #7 (permalink)
Old 05-18-2008, 07:50 PM
bigbub28 is starting off with a positive reputation.
i would also change the switch, ive put 3 in my 82 since it was new
  #8 (permalink)
Old 05-18-2008, 08:18 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
I disagree with the above. If the headlights increased the current through the switch when the voltage dropped, that means they would not dim(the wattage use would be the same). But they do dim, which means there is less wattage being used, which means less voltage or current is being used, or both are less(which is true in this case).
The next statement is true for some loads, but not the lights. As the voltage is increased, they get brighter, and more current is flowing and the wattage output of the light is increased. It's a well known fact that if you put a relay kit in your harness to decrease the voltage drop, and make more power available to the lights to make them brighter, the life of the headlights will be reduced because they are burning more aggressively, shortening the life of the filaments. Of course this is usually an accepted trade-off to get better lighting on the road.
Next time you may want to check the plug in the harness that the headlight switch plugs into. The connectors get loose, which causes the plug to melt and cause an even worse connection problem. The heat from the poor connection will also cause the circuit breaker in the switch to trip. I believe Ford used to sell a plug with pigtails for this problem.
__________________
Dave F
1989 F250 XLT Diesel
  #9 (permalink)
Old 05-19-2008, 02:35 PM
mward69 is starting off with a positive reputation.
Quote:
If it's when you hit the high beams, may be the high beam switch. I have the floor "kick" switch. Sometimes they would go out when I kicked them on...I replaced it for $3 and some change...took about 10 min. to change it out...no probs since.
  #10 (permalink)
Old 05-20-2008, 04:03 PM
woodbutcher05 is starting off with a positive reputation.
Have had the same problem.Replaced the dimmer switch,and that cured the problem.
Leo
  #11 (permalink)
Old 05-22-2008, 02:14 PM
Dimmer switch...headlamp switch...highbeam switch? Replace all three??
  #12 (permalink)
Old 05-22-2008, 02:48 PM
Dimmer and high beam switch is the same thing.Replace dimmer switch first.Its cheaper AND easier.
Leo
  #13 (permalink)
Old 05-22-2008, 03:14 PM
I would replace both, for good measure.
However, as I stated earlier, these switches should cause the headlamps to both blink on and off simultaniously. Not one side then the other.
The one side blinking, then both, suggests a wiring fault or other problem.
  #14 (permalink)
Old 06-02-2008, 04:24 PM
There is most likely some bad wiring somewhere. I glanced at it the other day and I noticed one of the wires going to the headlight bulb on the right side (the one I've been having the most trouble with) has no insulator on it. Sketchy... Someone must have messed with it. I'm going to look into it more... Thanks for the help.
  #15 (permalink)
Old 06-03-2008, 08:47 PM
XLnAK is starting off with a positive reputation.
Had the same situation in my 83 . Replaced the dimmer, Thought it was fine. Small time past , then problem started again. Couldn't recreate it at home with any certainty, so I replaced the switch with an aftermarket one. All better for about a month.Yikes ! (I have seen the head light wires you speak of , I think the wire shielding shrinks and exposes the copper after the years and besides that may get pulled back wires abit when pulling the connectors for bulb replacement.) So I open up the old switch (Ford) and the Now removed New switch and found the new switch had a very inferior build compared to Ford(motorcraft) part and that the new switch(made in chy) had been broken upon assembly(small piece floating around inside not related to my careful disassembly ). The Ford piece is of greater value. Thicker contacts and all. I went to dealer and bought motorcraft and Its working 3-4 yrs later. I've got the factory wiring diag. and if I recall the Two head lights are fed through separate leads into switch? But at any rate the switches do see alot of heat and can burn contacts. My 2 cent. Best wishes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
