Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 12:11 PM
shu5720 is starting off with a positive reputation.
wheel bearings??
Hey guys. Took the truck out today, a 2000 F250 XLT 4x4 and now can hear a grinding/dragging from the front end. Seems to be more pronounced turning to the right. I checked the drivers side and I can turn the u-joint but there is a lot of play and noise where it enters the knuckle. So I am thinking the wheel bearing/hub assembly. The pass side does not move, although I noticed the 4wd hub was just prior to being all the way to "free". There is also noticeable play where this side enters the knuckle. It does not sound like brakes, seems to be a heavier grinding like bad bearings but I wanted to check with the resident experts prior to tearing into it again. Thanks for the help, you guys are the best.
  #2 (permalink)
Old 05-17-2008, 01:06 PM
dyhrdford is starting off with a positive reputation.
Try jacking up the front of the truck and wiggle the tire top and bottom. Have someone watch what moves.
__________________
01 F-350 CC LB 7.3 PSD Lariat
  #3 (permalink)
Old 05-17-2008, 01:21 PM
yeah, that was my plan today/tonight. Let you guys know when i do.
  #4 (permalink)
Old 05-17-2008, 03:22 PM
SpringerPop's Avatar
Too old to be too smart
SpringerPop has a great reputation on FTE.SpringerPop has a great reputation on FTE.SpringerPop has a great reputation on FTE.SpringerPop has a great reputation on FTE.SpringerPop has a great reputation on FTE.
Tip:
If you decide that hub replacement is necessary, go to the dealership and buy the four stud bolts that screw into the hub. You DON'T want to even try to re-use the old ones.
They're about $4.00 each, and you need four.
If you don't, and decide to attempt to re-use them, you'll come out of the other end of the job wondering why you didn't just spend the money. :-))
Pop
__________________
-Marv-
"Striving to be the person,
that my dogs think I am."
2000 F350 Lariat 7.3 A/T CCLB4X4, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX. Email SpringerPop
  #5 (permalink)
Old 05-17-2008, 05:29 PM
Gmeanie is starting off with a positive reputation.
It might be just the needle bearing too.
  #6 (permalink)
Old 05-17-2008, 08:31 PM
Yup, meanie, it could be the needles, too.
Shu, take a look at this page as a reference:
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Pop
__________________
-Marv-
  #7 (permalink)
Old 05-18-2008, 06:33 AM
Springer Pop - i'll hopefully get it apart tonight. I looked at the link. It seems when I take the weight off the bearing and feel just the needle bearing moving, it's okay but will check that as well. Does anyone know if the ABS front hub assembly will fit non-ABS trucks?? I only ask as I could get them for about half as much. I realize its not right, just trying to save a few coins.
  #8 (permalink)
Old 05-18-2008, 12:38 PM
Jack_99V10 is starting off with a positive reputation.
Mine came with the 4 bolts from NAPA, using a friends account it was $350 for the ABS unit.
__________________
Not Pictured: My current ride - 00 F350 7.3L CC LB - DP - Tuned 60T-80E-120R-140A - 6637 - MUFFLER DELETE
  #9 (permalink)
Old 05-18-2008, 01:04 PM
ironmine is starting off with a positive reputation.
If the needle bearing is bad, the sound would dissapear when you locked in the hub.
Sure sounds like a bad whl brg/hub.
Good luck.
  #10 (permalink)
Old 05-18-2008, 02:46 PM
I got my last Timkin hub, a 515020, for $249 plus tax. This was not a Chinese part. Some parts houses are willing to "negotiate". :-))
Of course, I still had to buy the $16 worth of studs....
Pop
__________________
-Marv-
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
