Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-17-2008, 10:57 AM
travisg96 is starting off with a positive reputation.
Torque on 6.9
Just got my gaskets and am putting the head back on. Only thing is the back 2 bolts can only be reached with a U-Joint. Is this going to affect the torque from the wrench? Does anyone know where I can find the torque pattern and specifications online really don't want to go buy a manual and don't think my public library will have this manual.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-17-2008, 09:34 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
Start at the center bolt, just below the rocker cover.
Jump to the next closest bolt in a counter clockwise circle moving out till all bolts are tight.
Four steps to torque bolts, 40, 70, 80 and 80 foot pounds are the torque values.
As long as the universal is close to straight, it should not change the value enough to worry about.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
www.ford-trucks.com/guidelines.html
FTE Moderator in the IDI diesel forum.
WV Chapter Member
  #3 (permalink)
Old 05-17-2008, 11:57 PM
The one i the verry back is at aprety extreme angle not only am I going to be using the universal I will probably be using a 12"+ extention. The other one has just enough stuff in the way to not give the wrench clearance.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
